- I PUT A DVD in to watch. it wouldn't play so I tried to eject it and it wouldn't. I turned it off then back on it still wouldn't eject. is there a manual eject?TANKKS
A very common fault with DVD players is the mini tag switch that lets the CPU know when the draw is open or closed...if this is faulty then you will never get your DVD out! another Fault could be that the Eject switch is faulty either dry joint..or there has been some foreign subtance find its way in there and is causing it to short. to get your dvd disc out (disconnect the unit from the mains power) very important that you disconnect it!....next take a phillips screwdriver and undo all the screw to open the unit...the first the you should see is the black deck with the dvd there...using a small screwdriver there should be two small screws holding down the top plastic "T" Looking Plate take them out and pull the "T" plate up and the disc shoould be just sitting there on the axis...remove it...now put the screws back in the "T" plate and then put all the screws back into the outer cause of the unit!....now power up and just see if this has stopped the fault of it not opening...if not you need to take it back for reapair either at the place of purchase or a local repair store....But atleast you got your dvd back!!....hope this helps,ben
Was this helpful?
Yes
No
Popular Solutions for Emerson EWD2204 DVD Player /
DVD player will not play any of my home made dvd's audio or video. Disc error ---Please eject...
(More)
DVD player will not play any of my home made dvd's audio or video. Disc error ---Please eject disc--- Playback feature may not be available on this disc.
have a phillips spu3003wm/17 universal remove and looking for codes of emerson ewd2204 dvd/cd player...
(More)
have a phillips spu3003wm/17 universal remove and looking for codes of emerson ewd2204 dvd/cd player with vcr
there is a circle that blinks in the right corner of the screen and then it says there is a disc...
(More)
there is a circle that blinks in the right corner of the screen and then it says there is a disc error. How do I remove this circle from the right top corner? I think it might be from something on the remote control. It will not let me play any other disc that I know is OK.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
