Washer will not work!
Put in a childs sleeping bag, filled with water then stopped. removed sleeping bag, will not drain, will not spin, nothing. it did fill up with a bit more water after the sleeping bag was removed but i can't get the water out.
  • Anonymous Jun 02, 2008
    machine fills up then trips electric supply swich
  • 291 Answers
What type and model is the washer?
Posted on Nov 29, 2007
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
Should I hand-wash my sleeping bag?
Probably. I wash ours all the time. What is the material and filling? Down or feather bags are hard to wash and I like dry cleaning those.
For synthetic bags, load loosely in a top load washer or better yet use a front-load machine. The front loader tumbles the bag instead of using an agitator. Use minimum soap, and do an extra rinse. SPIN SLOWLY. You do not want the weight of the water to tear anything inside the bag. After it is done, then you can spin it faster because most of the water will be out. Then dry in the dryer. Some people say to put a couple of tennis balls in with it or an old shoe -- apparently to fluff it around a bit more.
Aug 05, 2012 | Camping, Backpacking & Hiking
Can you put a sleeping bag in the tumble dryer?
Mostsleeping bags can be tumble dried but on a low heat. Check out this article forsome more information about drying and generally cleaning sleeping bags http://www.rei.com/expertadvice/articles/caring+sleeping+bag.html
Jul 30, 2012 | Camping, Backpacking & Hiking
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
