Question about Roper RAS8445KQ Top Load Washer
ROPER WASHERRAX6144EWO I AM A WOMAN TRYING TO FIX MY ROPER WASHER. IT WILL NOT AGITATE.UNDERNEATH THERE IS SOMETHING LIKE A RUBBER TYPE BELT THAT IS ALL MESSED UP. IS THIS A BELT AND IF SO HOW DO I GET THE BACK OFF TO REPLACE IT.
  • 1 more comment
  • PAT DORTCH Nov 29, 2007
    I WILL DEFINATELY TRY IT. I DID SEE WHERE A PIECE OF RUBBER TYPE THING SEEMS TO BE ROTTEN. IS THAT THE COUPLING? ALSO THERE IS SOMETHING THAT LOOKS LIKE A BELT THAT IS STRETCHED OUT AND DOES NOT FIT TIGHT ANYWHERE. I THOUGHT THAT MIGHT BE A BELT. NO? THANK YOU, YOU HAVE BEEN A GREAT HELP AS WHERE I MAY START... PA
    THE MODEL NUMBER THAT I SEE IS RAX6144EWO....COULD IT HAVE A BELT TOO?
  • fixit4me Jan 08, 2008
    My 15 yr old washer will not agitate. It does if there is only water and no clothing in it.
If that is a coupling--2 white plastic pieces holding a rubber coupling? Rubber with three holes? If so, you need to remove 2 holding clamps to the water pump above the motor, separate it, remove two screws and 2 larger holding clamps of the motor, pull motor out and replace coupling...alingn motor and coupling onto gear, clamp it and return pump into its place.
I am new here, tried to post a photo of what I think you have but cannot just yet. Still trying.
Posted on Nov 28, 2007
SOURCE:
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
The rinse and dryer are not functioning.
Whirlpool ,roper ,kenmore all have direct drive for the spin & agitate cycles the coupler is underneath about center behind the motor. It is a plastic coupling with a flex coupler made of rubber on both sides. Part #1195967 usually run between 12-20 bucks if this doesnt fix it you probably have a bigger problem motor or transmission.
Nov 15, 2009 | Whirlpool Washing Machines
RAS7233KQ0 fills but will not agitate
you probably have a loose or corroded wire to your agitate solenoid unplug the washer and, visually check this
Jun 09, 2009 | Roper RAX4233PQ Top Load Washer
Roper top load washing machine problem. Please see details...
probibly a coupled drive. motor coupling runs everything, pump,aggitator, spin. if none of these thrree, coupling is two plastic parts with rubber between directly on the shaft of the motor , see if there are two screws at the bottom of front of case., if so remove aathen look for clips at top rrear this should be an easy fix
Mar 27, 2009 | Roper RTW4100SQ Top Load Washer
Changing a belt on a kenmore washing machine
99% of kemore washers (anything after 1950)
dont have a belt. and
the back does not come off for repair, the front does, with the removal of 2 screws
If the washer does not agitate or spin the usual cause is a plastic & rubber coupling between the motor and gearbox. replacement gearbox couplings now have a metal hub to prevent further breakage.
If this matches the problem you are trying to fix, reply & I will step by step the replacement process, its 2 screws, 2 bolts, a hammer & dowel & some time, to fix
Oct 11, 2008 | Kenmore 24032\24036 Top Load Washer
MAV Atlantis 6000
hi. thanks for the question .the clicking sound is something caught, in water pump. the rubber smell is the belt . pull washer away from the wall. small door at the back left corner ,remove pump on the floor. remove 3 3/8 bolts remove. replace . belt underneath washer . replace thanks the appliance doc please rate me
Aug 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Roper Washer spinning cycle problem
This happened on mine as well. I determined that the clutch was bad. These are not belt driven but rather direct drive with a clutch/brake that controls the spins and agitate functions. Try washing an empty or very small load (like tshirts and underclothes) and see if that helps. ALso look underneath to see if there is any oil on the ground if so you most likley will need to replacet he cltuch mechanism... not an easy task for do it yourselfer!
Apr 05, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
104 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Gerry Harvey
Gerry Harvey
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
