Question about Sony PlayStation 2 (PS2) Console
PS2 won't work, red light comes on, buttons don't respond
Hi, the red light on my PS2 comes on steady when I switch the power ON but nothing happens when I push the buttons on the front of the console.
My father took the console apart awhile ago when it stopped reading our disks. The system made a clicking noise while trying to read the disk and then the "Disk read error" message appeared. I think my dad replaced the ribbon wire attached the the back of the buttons. The console hasn't worked since.
I took the system apart myself to clean the dust out of it and didn't see any obvious physical problems(melted or broken wires, etc.). I noticed 2 fuses in the left half of the system so I tested them with an ohms meter. They both had good continuity. I don't even know if they could have been related to my problem.
The PS2 I am having trouble with is one of the original ones that first came out. I bought another PS2 about 2 years after they started but I can't use it as a model for the first one because it is slightly different internally.
Any help would be greatly appreciated. Thank you
  • the fat man Dec 17, 2007
    the power buttons dot turn on and i thik i broke the wire connecting them how do i connect them back
What if the ribbon wire riped how do i put it back
Posted on Dec 17, 2007
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Sounds like the ribbon cable is ether damaged or not in the slot all the way.. that clicking sound you hear is common after extended use, all mine make the same sound ..try opening it up one more time and check the ribbon ends i know it's a pain but might be worth your time. pulling them out too hard can damage the ends.some time's putting them they seem like there in all the way but it might not be in straight.REMEMBER BENT FOLDED FLAT CABLES = problems.
Posted on Nov 29, 2007
SOURCE:
Poweredge SC 1420 won't come on, it keeps blinking an orange light on the power button and the lights below the power button the first 3 indicator lights are orange. I tried unplugging and plugging it...
hi,
I have several of these and most often there power supplies blow. since they come by default with only one powser supply. the system won't start
I would start there as most other problems will generate beeps.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
Can't get to booklist won't respond to touch
Hi!
You can try hitting the reset at the bottom for 3 sec. and then slide the power switch.
If the unit gets froze you can try the following:
1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer
2. Hit the reset button for 3 seconds.
3. The red steady light should come on, if not, try the reset again while the unit is connected
4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.
5. Disconnect the reader and see if operational.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org/
Aug 04, 2011 | Sony Reader Touch PRS-600
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Ps2 dual shock2 controller buttons not working
Removed accumulated dust sticking on the board were the buttons touches.use cotton balls with alcohol or use clean damp cloth.If nothing's happen check the cord I'm sure it is twisted badly, open your ps2 use this controller and try to twist back the twisted cord if it stopped sometimes when your twisting it then you have to replaced the cord(make sure that your using the original ps2 controller not imitation)pls. rate
Jan 17, 2009 | Sony PS2 Dual Shock 2 Controller...
PS2 No Green Light
Maybe it has something to do with your power supply, try replacing it with a different one.
Jun 09, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 rock band guitar not working
You have to synch it by pressing the button on the usb connection and then turn it on with the clear button
Mar 08, 2008 | Sony PlayStation 2 Slimline Console
My playstation 2 won't turn on at all
my ps2 it get power it red when i press the reset botten it wont turn to green
Nov 10, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
