Question about NEC Lands Phones
On a NEC SeriesI D-Term phone behind a SV8500. How do I save the handset volume after I set it?
3 Suggested Answers
SOURCE:
  • 201 Answers
SOURCE: NEC DTERM SERIESI
You may be right about it coming from another extension! If that is the case you need to return the message by pressing the key, finding out what extension is ringing and answer the phone otherwise the message will never be returned and the message light will stay on.
Quite an annoying feature with many phone systems. Nobody ever uses the feature and people have no idea what's happening when someone else accidentally presses the wrong key at the wrong time.
Posted on Oct 24, 2007
bbl242003
  • 1637 Answers
SOURCE: I get the term "volume low" on my cordless phone
Hello patricia arr, I have a solution for you.
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award/PROVIDE "POSITIVE" FEEDBACK
PROVIDING FEEDBACK WILL ALLOW US TO CONTINUE SUPPORTING YOU IN EXPERT SOLUTIONS Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
I would like for you to set up all your uniden phones for the charger jacks. Then please wait several minutes for the phones to gain a suitable charge for TESTING. Before picking up a phone to test it, please unplug all phones for electric power , THIS INCLUDES the charging jacks, answering machine, main unit etc. Wait one minute then plug all devices back in. If your still have issues, please take out the new battery that you purchased and try it on a different uniden phone. If the problem persists, then the battery (NEW) is a bad battery. If the problem does not persist, then you know it is the HANDSET. Please come back with more issues as I would love to provide expert solutions for you free of fee.
Posted on Jan 11, 2011
Turn ringer volume up on NEC Dterm series i? I have tried adjusting while ringing but the LED volume shows up still
You need to lift the handset first then adjust the volume via the large silver round button on bottom right of phone
Feb 27, 2015 | NEC Lands Phones
Dtp 32d manual
The DTP phones work on at least 8 NEC systems, so please mention which one you have. Pro II, IPK, IPK II, Elite, SV8100, SV8300, SV8500, 2000, 2400, or one of the more run of the mill systems. Some vendors have PDF versions on their website if you Google the specific guide you need, and add PDF in your search.
Jun 23, 2014 | NEC Dterm DTP 32D-1 Corded Phone
Volume settings dont save on Mitel 5312 ip phone
You can't save the volume if you put it up to 10. Set it at 7 and see if it saves. If not volume save in the class of service option is not enabled
Jul 18, 2012 | Mitel 5212 IP Phone
Voice Mail
It depends on what type of phone system your terminal is running on. On a NEC 2400 IPX and SV8500 for example it's ASYD sys 1 index 140. A 2000 & key system is different.
Mar 22, 2010 | NEC Dterm DTP 16D-1 Corded Phone
How do you change stations names on a NEC Dterm 80?
ANDD if it's a NEC IPX 2400 or SV8500. PBX administrator will have to change it.
Mar 18, 2010 | NEC Dterm DTP 16D-1 Corded Phone
How to change time on NEC Dterm Serier III?
ATIM if your PBX is a 2400 IMX,IPX or SV8500.
Mar 17, 2010 | NEC Dterm DTP 16D-1 Corded Phone
How to program speed dial numbers?
To Set:
Do not lift handset
Press FNC button
Press the desired “One Touch” Key
Enter number to be stored (remember”0” for external numbers)
Press FNC button to save
To Dial
Lift Handset
8
Press desired One Touch key to dial
Jun 25, 2009 | NEC ETJ 16DD-2 Corded Phone
The #2 handset has the ringer off and I can't get it to come on
(for land line) Behind the phone one volume adjusting button is there, medium & loud you have to select loud one,or cell phone first go to menu then setting, then tones then ringing volume you have to adjust volume maximum and save changes.
Jan 25, 2009 | Lands Phones
GE 28851 base handset #1, will not save ringer tone or volumn I selected. Brand New.
As it turns out, the primary base handset did save the newer selected ring tone and volume level setting.
However, the base maintains its own ring tone and volume level setting from factory.
Therefore, the base will present its own settings along with the handset setting during an incoming call.
So, one has to lower the volume of the base (in non-talk mode). The base should display in window: LO.
Then, only the ring tone and volume level selected for handset will be presented during an incomiong call.
How did I do????
Ken
Jul 09, 2008 | Uniden Cordless Phone
Ringer Volume
I am assuming this is on a DTU 16D nec phone. On the right side of the phone is a volume up and down button. If someone calls you, you adjust this while the phone is ringing. If you adjust it after you answer it controls the voice volume (what you hear through the ear piece) if you adjust it while the handset is down but there is no one calling you it adjusts the display contrast on the phone.
May 04, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
18 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Norman Al-Anbar
ray gallant
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
