Question about Canon DV-MV830i Mini DV Digital Camcorder
Tape insertion hi, the camera will let me put a tape in but won't retract the tape into the camcorder, when i remove the tape the retracting mechanism works fine.on the screen the message says to remove the tape.please help
  • 6 more comments
  • muzzle Feb 11, 2008
    This also happened to me, after having problems with the heads, and power issues. I think it is to do with the heads, possibly condensation.
  • Anonymous Apr 07, 2008
    I have the same problem. It won't retract when I put a cassette in. What can I do?
  • Anonymous Apr 14, 2008
    hey i got the same prob with the camcoder..any help?
  • bensmith May 31, 2008
    same problem, just keeps spitting it back out and saying "remove cassette"
  • Anonymous Nov 30, 2008
    Same problem.
    Camera only 2 years old . disgusting.
    Cant even accept head cleaning tape.
  • wickedboyno1 Dec 11, 2008
    wont work with old tapes or new. old one was inside camera, and had been sat in there a while. as soon as i turned the camera on, it spat the casst out and refused to take anymore in.
    any luck?
  • smoody39 Dec 20, 2008
    I've had this camera for just over 2 years its been hardly used, really annoyed!!!!!!!!!!!!
  • jacBE Apr 06, 2009
    Tape mechanism fine but when i put tape in nothing happens for 5 seconds then remove casette beeps up on screen :( Won't load any cassette.
It's dirty inside, you need to send it off to be cleaned.
Posted on Jun 12, 2008
3 Suggested Answers
mistersony
  • 320 Answers
SOURCE: Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Posted on Oct 20, 2008
SOURCE: Cannot insert tape into canon MV800. Always ejects
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Posted on Dec 18, 2008
The cassette door to this camera will not retract when I try to close it. as you probably know you close the door partially, the casstte holder retracts and then you can finish closing the door. When i...
Hi.
My name is Rick and I am the owner and technician of Discount Camera Repair. The problem you are experiencing can be repaired fairly inexpensively but will require disassembly by a qualified technician. The camera will need to be disassembled to remove the tape mechanism and then the tape mechanism will need to be disassembled to repair. If I can be of any help please call or email me and I'll get the camera working for you.
Dec 27, 2011 | Sony Handycam DCR-IP5 Micro MV Digital...
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
The camera will not load a tape. Without a tape installed the loading mechanism works as it should. when a tape is placed in the camera it does not retract into the camera but opens back up as if to eject...
Symptom shows Dew sensor is activated and most probably you will see water-drop yellow sign flashing in LCD.
Remove battery / power source from camcorder and leave it for 1-2 hours, reattach battery/ power to camera and turn it on and check.
Thanks.
Nov 05, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
I found a loose part in the VCR bay I'd like to reinstall. Part #T5B
I found that part #T5B was on the bottom of the VCR tape tray on the right side of the VCR tape bay opening and was spring activated by inserting the tape to allow the tray to retract into the player mechanism. Without a tape installed, part T5B prevents the tape carriage from retracting.
However, I still couldn't get the whole mechanism timed properly, and gears were skipping teeth, the mechanism was still binding, and shutting the power for the whole player down. Therefore, I removed the rubber drive belt that operated the VCR tray insertion/ retraction process, and disabled the VCR side from operating at all. This allowed the power to remain on and allow the DVD side to work properly.
This worked only for the Phillips DVP3150V/37. I cannot say for certain if other Phillips players are the same.
Oct 12, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Inserting tape into camcorder
bent guide pins, dried out grease, belts got old although you say new, some object stuck inside jamming gears.... the list goes on.
Mar 22, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Tape holder jammed
remove the battery and use the charger - press eject button repeatedly , while plugging charger in ( if mechanism is out of alignment , will start to eject but reload immediately ) ;
Jul 11, 2007 | Panasonic NV-GS17 Mini DV Digital...
Hi Everyone,
Hope this helps
Mar 09, 2007 | Canon MV800 Mini DV Digital Camcorder
Tape ejects a third of the way and stops
I believe that you have a problem where the tape is not being taken completely back into the cassette housing. Either the tape is bad and jammed or the idler is slipping. As it starts to eject pressure is put on the eject mechanism and it stops and reverses (as it is suppose to) to keep from damaging the camcorder. Unless you are familiar with camcorder repair you could do more harm than good forcing the unit open or trying to get the tape out. You should take it to a repair shop and let an expert take care of it. It shouldn't cost much to remove the tape and check for damage. Perhaps $50 to $100 US. Good luck.
Jun 11, 2006 | Sony Handycam DCR-TRV740 Digital Camcorder
Canon DV-MV830i Mini DV Digital Camcorder Logo
315 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
