Question about Canon S400 InkJet Printer
How do I replace the waste ink pad on my Canon S400 printer?
My printer started screaming, groaning and grinding, the light was flashing (didn't notice how many times), paper wouldn't feed through properly and print was patchy, especially black. I got an error message just saying the error would require a service call.
I cleaned around a bit inside the printer, blotted up as much ink as I could from the waste pad and followed instructions to reset the counter. So, I think I'm heading in the right direction.
The printer is quieter now (though still not like it was, and a bit clunky when the cartridge moves in and out of the right side), print is much better but now there's a faint stripe down both faces of the paper, on the right hand side of the printer.
I saw a tip that said you could remove and wash out the ink pad, but can't work out how to get it out of the printer - I haven't been able to get the top off because I can't manage to move all 3 tabs at the same time. Also, should I clean the back of the cartridge or the gold pins they connect to? If so, what's the best way?
It's been a great printer, never had any problem until now and don't want to replace it, so would really appreciate it if you could help me. Thanks!
Thanks, I'll try this - sounds a lot easier!
Posted on Dec 03, 2007
    Scholar:
  • 74 Answers
Before you "mess" with the ink pad, try cleaning the print head rail. This is the chrome rod that the print head rides on. Use a little alcohol on a soft rag. After cleaning it, wipe a thin layer of oil (3in1 or sewing machine oil) When you power back up it should go through the rutine of cleaning the head etc.
Posted on Nov 28, 2007
SOURCE:
Ink light and paper feed light are flashing alternatively, printer not responding at all !
I just had this same problem, and came here to figure out what to do about it. Turns out I had the CD/DVD tray in the out position, so all I had to do was flip the switch to stow it and the flashing lights stopped. Maybe it will work for you as well.
Aug 22, 2009 | Epson Stylus Photo R260 InkJet Printer
My printer needs to have the waste ink reset how do I do this
You can try this....
  1. Turn off Canon S300, S400, S9000 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon S300, S400, S9000 Printers should respond as normal.
But this happens because the waste tank is full. You need to locate it and use a paper towel to absorb the waste ink. Whenever the printer cleans itself ( when a new cartridge is installed, for example) some ink is cycled into this chamber. So if you reset and it is full, overflow may occur.....
Jul 23, 2009 | Canon BJC S300 InkJet Printer
My printer is not working since we had a power outage.
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The flashing orange and green alternately light indicates that the error the printer is experiencing requires it to be sent into an authorized canon service facility.
Replacing the waste ink absorbtion pads is something the service facility can take care of for you. Once they are replaced, it'll be functional again.
May 28, 2009 | Canon Office Equipment & Supplies
Message "wasted ink tank near full" on Canon Multipass F80
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Reset waste ink counter on Epson C60 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Feb 24, 2009 | Epson Stylus C60 InkJet Printer
Power light and red light keep flashing alternatively
If both lights are flashing alternately, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utilit to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
Waste ink absorber full
CANON WASTE TANK RESET CODES
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
8. Your printer should respond as normal.
Sep 04, 2008 | Canon Office Equipment & Supplies
Canon printer i 475D
This may be worth a try
1. Turn off printer
Jun 28, 2008 | Canon Office Equipment & Supplies
Canon s400 doesnt print only blinks eight times
The tank is situated on the RHS.
The Print Head rests there when not in use.
Open the flap to expose the Print Head,slide the Print head across to the left.
On the area where the Print head rests, there is a black plastic square of plastic which contains 2 narrow vertically positioned ink pads.This is also spring loaded.from underneath.
The pad on the left is for BLACK the other Color.
These become saturated with ink during the cleaning process.
I suspect the Print Head has a built in sensor to detect overloaded waste tank.
The pad can be removed this by hooking it out, sideways.
Unless the pads are leaking ink everywhere I wouldn't remove it.
Use Cotton Buds to soak up the excess ink. I used about 15.
Then.....
Turn off printer
Hold down RESUME button and press POWER button.
Keep holding down POWER button and release RESUME button.
Press RESUME button 2 times, then release BOTH buttons.
The GREEN light will flash and stop flashing.
When the GREEN light goes out, press the RESUME button 4 times.
Press the POWER button and the printer should turn OFF
If not press the POWER button once more.
My experience was when turning the printer on at a later date the POWER and RESUME lights still flashed.
All I did was press the RESUME button and the printer operated as normal.
Jan 06, 2008 | Canon S400 InkJet Printer
Canon S400 InkJet Printer Logo
152 people viewed this question
Clive
Clive
old marine
old marine
Ekse
