Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Water supply just moved into new house with admiral fridge would like to know what pipes to connect to water supply so ice maker works any help would be grateful. cheers Don.
  • 709 Answers
Hi Don,
Cold water supply at Fridge location. Run 1/4" tubing and connectors to match the supply valve and solenoid valve on the Fridge. Should be just one tubing connection.
If you do not have a supply at your Fridge, you can shut off your main supply and tap into the cold water line and run you a supply over to the fridge. use 1/2" PVC pipe and fittings to route over to the fridge. Get a Threaded adapter to connect a shutoff Valve. This way you have a way to keep the main supply on and hook up the Tubing from the fridge to the supply.
Posted on Nov 28, 2007
How do I turn off the water to my icemaker on Kenmore Model 253.7818480 Refrigerator?
If your fridg is plumbed like most, there's a valve under your kitchen sink that controls the water going to the fridg.
Jun 12, 2015 | Kenmore Refrigerators
Ice not forming in ice tray
Hi - there are several problems that can cause this - but ultimately, if your freezer is keeping frozen foods frozen, the problem is lack of water flow.
Most automatic ice makers work on a timer. At a regular interval, if the ice maker arm is down to signal a "not full" ice bin, the heater on the bottom of the ice form turns on to break the bond between the ice and the mold. After a short time, the wiper linkage turns to allow the wipers push the individual cubes out of the mold and fall into the bin. After that, the solenoid on the water line is energized that will allow the water to flow to the ice maker to fill the mold, and then shuts off.
The water may pass through the filter inside your fridge (if equipped) and the filter may be clogged (if you can dispense water from your fridge and it works - this not likely to be the problem). Some fridges require a filter to be present - other will work without a filter - but none will work with a clogged (or frozen) filter. Make sure the fresh food compartment of the fridge is not freezing the filter.
Most of the ice maker functions are silent - except for the sounds of the ice dropping into the bin, and in some cases, the "snapping" or "clicking" of the water solenoid turning on and off (coupled with the sound of water running).
See if you can hear this happening. If you do, the problem could the either the flexible water line or the point of the water line attachment to the cold water pipe in the house. If you moved the fridge out for any reason, it is possible that the water line has been kinked or crushed when the fridge was moved back into position. If it has been undisturbed, it may be related to the valve that supplies water to the fridge. Sometimes, a clamp-on pipe piercing valve is used to connect the smaller fridge water line to the cold water pipe in the house. It is not unusual for these to give trouble after several years - particularly in areas with "hard" water. It may be worthwhile to replace this if it has been installed for some time.
Lastly, it may be the ice maker itself. It has heaters, switches and motors - any of which can fail and cause trouble. You could pour water into the the maker with a watering can or similar and let it make ice as normal. If ice is never dropped into the bin, then something on or cabling to the maker itself has failed and will likely require professional service or replacement as an assembly.
These should get you going and may pinpoint the issue - good luck!
Apr 08, 2013 | Refrigerators
LG LFX21976ST refrigerator. Started the day with a full reservoir of ice, was using it heavily to keep some workers hydrated. The last time I tried to get ice, none came. Per the label inside the doo
The ice maker's water supply line may be frozen solid. Do not worry... take out your frozen groceries and dairy products, and let your friends store them for two days while your completely defrost your refrigerator. If you don't want to wait, try to locate a schematic (parts diagram) for your fridge and take a panel access cover off to get access to the copper tube of the water supply line inside. (Warning: this can be terminal to your fridge so don't attempt this without the exact parts diagram for your make and model.) Ensure you are heating the water pipe and NOT the refrigerant line; i.e., freon, ammonia, etc... Unplug your fridge and heat up the (water supply) copper pipe with a high wattage blow dryer... if you were a pro, I would recommend a heat gun. DO NOT USE A HAND TORCH as the soldered joint connections may come loose and it will leak afterwards. (The demand you placed on the ice maker caused the compressor to run almost continually for the ice maker assembly causing the copper pipe water supply pipe to freeze... it will take time to thaw it out by just unplugging it. In the future, when you know you need volumes of ice... make a little at a time each day and store it inside a separate ice cube container.) You may also want to check the activation lever above the ice cube container (bin) to make sure it moves freely against the switch contact. If the switch contact is jammed, it won't work. Good Luck
Oct 02, 2012 | Refrigerators
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
Ice Maker stopped working -- new fridge 3 months old.
Good day,
Icing could be one problem. The first thing to test is the water supply to the machine. Shut the house off at the meter. Remove the line from the water valve at the machine. Insert the line into a bucket while someone else turns on the water at the meter for a 15 second count. It should come out forcefully, not weak or just dribbling.
If it's bad, then the line and the fittings where it connects to the house supply should be inspected, and cleaned or replaced as needed.
If it is O.K. and the machine is under one year of age, it is under warranty and you should call your selling dealer for a free service call.
Jun 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator does not produce ice or water. Kenmore Elite Refrigerator Model Number: 795-775-69600
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Mar 12, 2010 | Kenmore Refrigerators
Have moved into new house with Admiral freezer/fridge/icemaker. Leaks water onto floor from time to time under freezer. Ice maker not connected to water supply so not that.ANY SUGGESTIONS?
Defrost drain is clogged causing this problem. Clear the dfrost drain and pan from inside the freezer section by removeing the freezer back cover plate and you will see from there. No extra parts required just patience.
Feb 01, 2010 | Admiral 26 cu. ft. Side-By-Side...
Hooked up waterline to side by side frigiedaire,
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 12, 2009 | Frigidaire GLRS264ZA Side by Side...
Problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Mar 30, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
140 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
