Question about GPX PDL805 Portable DVD Player
My GPX PDL 805 will not function on the battery-
I used my dvd once on the way home in the car on a long trip - It worked fine. However, the battery was totally used up. I put it away for several weeks and then took it out and charged it for at least 6 hours. Now it does not work at all unless it is plugged in. How can i need a new battery when it was only used once? Ansd where do i get such a battery if i need to? Eileen
  • Anonymous Dec 28, 2007
    I have a very similar problem, i just got it and the battery does not hold any charge.
  • Anonymous May 28, 2008
    Bought a GPX PDL895 DVD player and after two uses the battery won't charge. Don't know what to do except buy a new battery.
  • 709 Answers
Hi Eileen,
Heat can kill a dead rechargeable battery. You can get batteries on Ebay. You just need to know the number off the label.
Posted on Nov 28, 2007
Gpx tde3280
check the gear inside for broken parts and check the belt also
Dec 03, 2017 | GPX Televison & Video
Get a replacement battery for my gpx pdl 705
www.batterymart.com/c-portable-dvd-player-batteries.html
www.batteriesplus.com
Nov 26, 2014 | GPX Televison & Video
I need RCR3273R remote codes for a GPX D1816 DVD player.
I'm not sure you're going to be able to use that remote for that DVD. Philips / Magnavox remotes don't list codes for GPX equipment. I've managed to find a couple of codes that might work but no guarantees here:
0699 or 0769
Your best hope is to use the auto search function on the remote control. If that doesn't work, then it's unlikely the remote will work for you. Do you still have the instructions for programming the remote?
Please don't give me a low rating if these codes don't work. This is a difficult request and I've searched as many sources as I can find. Thanks.
Oct 16, 2010 | GPX D1816 DVD Player
Batt will not charge, i bought a new one and it not charge up either. plays dvd just fine what is going on?
That simply shows the fault is not from the battery.
Have you checked if the charger is working fine?, first check if the charger is working fine by testing it on another lasonic pdl305 portable dvd player to see if it is working.
If it does not work then you have to replace the charger.
The next thing to check is the charging port, to test this, try to use a tested ok charger on it to see if it works.
If it does not, then you can tell it is the charging port that has a problem. All you have to do is replace the charging port.
That is How you detect the fault and fix it.
Take care
Jun 15, 2010 | Lasonic PDL-305 Portable DVD Player
04 Pontian Montana DVD, dead battery
sound like a fault in dvd player.its running battery down.have dealership check it out.sound like a electrical problem.
Jan 03, 2010 | 2004 Pontiac Montana
2001 Camry Often Won't Start When Hot Outside Unless Jumped
well is the battery draining over the time its sitting?
could be a bad battery or alternator, and/or you might have something on the car constantly draining power from the battery.
best to have it looked at by a mechanic.
Aug 09, 2009 | 1994 Acura Integra
Flashing Battery Symbol on GPX PDL805
The appearance of a battery symbol while you are using just the battery means that you are using just the battery.
That's it.
No Problem.
The flashing battery symbol is a constant reminder to you that a power intensive function is only supported by the battery, and that you should make external power available so as to complete the task without losing power in a battery drain event.
May 07, 2009 | GPX PDL805 Portable DVD Player
Multi region code for GPX PDL 705 portable DVD player
I hope this helps^^ try it and gimme a shout!
Turn on power.
Open lid.
Push 9 7 3 5 from the remote.
Select 0 using arrow keys.
Exit Setup.
Done.
The one above did work me, only that after one turns on the player, enter in the 9735 with the remote and press 'enter', you can choose between making your player region-free or a different region in addition to R1. Select the desired region unlock and press 'enter'.
Make sure you check the bottom of the DVD player to see if it was manufactured in the first quarter of 2007, that might factor in whether the code can work or not.
Apr 01, 2009 | GPX PDL705
Tip polarity on GPX PDL 705
it is positive
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger GPX PDL705
Nov 28, 2008 | GPX PDL705
GPX PDL805 Portable DVD Player Logo
214 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
