i have a 7500BTU window AC that is not working properly. i think it may need freon, but have no idea how to get it/how to use it/how to put it on. for a 10x20 ft. room, at 68 degrees i should be cold, but i am still with not even using a sheet.
most window ac do not have a service valve you would need to get a A-1 valve and have it installed if you can do this yourself then go ahead but if you have to get it done then you should just replace the unit
Comments:
Aug 12, 2009
- most window ac do not have a service valve you would need to get a A-1 valve and have it installed if you can do this yourself then go ahead but if you have to get it done then you should just replace the unit
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool 8,000 BTU Electronic
I have an Amana Gas Fired Furnace Model CCA24FCC. It recently started blowing cold air out of the...
(More)
I have an Amana Gas Fired Furnace Model CCA24FCC. It recently started blowing cold air out of the vent registers in the house and would then shut off after a call for heat at the thermostat with the setting on Auto. In the ON setting the circulator fan just blows ambient temp air. Upon further investigation I found I have a blinking LED. It blinks three times. The manual says- pressure switch circuit not closed. That is the case because the induced draft blower is not spinning. When a call for heat occurs this fan should spin. The pressure switch is functioning- with the furnace off or not operational the switch has no continuity across its terminals. When I pull a slight vacuum on the switch, I can hear it move and then my ohmeter has continuity across it. The problem is the draft motor wont run. When the furnace is switched on or a call for heat occurs, I do not have any voltage at the induced draft blower motor terminals nor do I have voltage at the control unit terminals. Am I on the right track to replacing the control unit? By the way, I had skipped replacing my filters for a few months and they were really dirty when I replaced them today while diagnosing the furnace.
It has an arc protecting plug with a little green lite that shows power and a reset button. The...
(More)
It has an arc protecting plug with a little green lite that shows power and a reset button. The little green lite works but the air will not turn on. Also the digital pannel dose not lite up. Please help. Thanks
the display on my ac shows 89 when i turn it on and the compressor never kicks on. i turn the...
(More)
the display on my ac shows 89 when i turn it on and the compressor never kicks on. i turn the thermostat as low as it will go and it never kicks on??
