Question about Biostar P4M800 Pro-M7 (P4M8PROM7) Motherboard
Boots, no video signal.
I attempted to upgrade my system RAM from 1gb to 2gb. In doing so, I caught a hint of a whiff of smoke/something acrid. Now, the machine boots, but the monitor is not getting a signal using either the onboard video, or the graphics card.
  • 31 Answers
First try removing the memory you installed and see if it boots normally. If that does not work then try replacing the original memory with the new memory.
If the motherboard beeps at you then look up the beep code pattern in the owner's manual. If you do not get any beeps and no video output at all then it is possible the motherboard or processor was shocked. You can try testing the motherboard with another compatible processor. If that does not work then it is likely the motherboard is bad.
Hope this helps!
Posted on Nov 28, 2007
SOURCE:
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
Aug 23, 2013 | HP Pavilion ze2000 Notebook
Upgrade my RAM from 1Gb to 2Gb everything is working but the cumputer still register 1 Gb of ram
Did you buy a 2GB ram stick or did you buy 1GB ram X2 so in your laptop you have only 1 stick of ram in there thats 2GB or do you have 2 sticks of ram in there which are 1GB if you have 2 sticks in there means one of them dead and is not registering it on your computer if you have only 1 stick in there thats 2GB but your system only reading it as 1GB then you will need to update your bios as it could be set only to read 1GB
Jun 28, 2011 | HP DV9410US Pavilion Notebook
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
I added an additional 1GB of RAM card , but my computer will not recognize the additional memory. I tried swapping cards between the two slots , nothing . The specs say the motherboard can handle 1GB per...
If you have the additonal memory in the system correctly, it should be recognized.
Attempt to boot the system with just the new stick in. If it boots you most likely have a motherboard issue. If it doesn't, it's just a bad stick of memory and I suggest just getting a new one.
Mar 05, 2011 | E-Machines W6409 (7234) PC Desktop
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
Lenovo 3000 y410 graphic card upgrade?
Lenovo Y410 System RAM can handle up to 2GB of memory. Since the machine has 2 slots for RAM and you already have 1GB preinstalled with the computer all you need to purchase is another stick of 1GB RAM.
There is no chance of upgrading Graphics card since it doesnt have a video card slot and the preinstalled VCARD is onboard.
Should you have any other questions just please leave a comment.
Cheers~
Jul 14, 2010 | Lenovo 3000 Y410 Notebook
Acer Aspire 5610 RAM upgrade issue. Sorry, it's long-winded. I included everything. lol I'm trying to upgrade from 1GB (two 512mb modules), to 2GB (two 1GB modules). The max for this machine is supposed to...
first refer to the motherboard's manual and see the max. RAM support.... then go to system properties | advanced tab | start up and recovery | go to settings under system failure....uncheck automatically restart
then when the blue screen appears....note down the error message and error code.... post the message and code to me...
this might ease your problem a little bit....
Jan 11, 2010 | Acer Aspire 5610 Notebook
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
Biostar P4M800 Pro-M7 (P4M8PROM7) Motherboard Logo
177 people viewed this question
Top Biostar Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
