Home | Web Cameras | Installing a Qui...
Web Cameras
Problem for Web Cameras
Generic problem for all Web Cameras
Installing a Quickcam 10.0A into USB2.0 por...
By Retreiver5 on Nov 28, 2007
It installs up to the point of the driver for the webcam. It tells me windows have found the driver software for this device but encountered an error while trying to install it. It indicated the extended attributes are inconsistant
Same Problem
Jan 18, 2009
-   tengo una camara logitech quikcam version 10.0A pero no me permite ninguna funcion el msn, pero en el software de ella si puedo tomar fotos y video. la instalé denuevo y el problema persiste, que puedo hacer? -   cambahuasi
Jan 11, 2009
-   doesn't acknowledge web cam won't cennect web cam-   smudgy2
Solution #1
posted on Jan 14, 2009
Somewhat Helpful)
yooperbud
Rank: Wiz  Computer Accessories  Expert
Rating: 82%, 2020 votes
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Was this helpful?
Yes
No
Popular Solutions for Web Cameras
Questions and Unsolved Problems for Web Cameras
Answer
We are looking for a basic web cam for outside use that we can record/monitor from a computer. Any... (More)
Answer
I am trying to install Micro Webcam Basic, Model No: IC 50 C from a CD, It tells me there is an... (More)
Answer
Hello, I have Logitech QuickCam S5500 with Logitech Webcam sw v. 12.10.1113.0000 without Logitech... (More)
Answer
My comp tells me there is an interanl failure :0x80040707, It will not download the cam Model No: IC... (More)
Answer
hi i want a driver for my hp cam its cif chip usb web cam
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Web Cameras:
Top Web Camera Experts
Rank: Guru Guru
Solutions: 14744
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Web Camera Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
