Question about Siemens Gigaset 8825 Cordless Phone
Siemens 825 Gigaset
I have an intermittent problem where certain incoming calls local or long distance cause the phone system to ring, cut out, ring, all the lights blink, then stops. While this happens you can't talk on the phone.
Anyone have this issue?
Thanks
  • 2 more comments
  • Anonymous Jan 11, 2008
    I just started having the same problem with my 8825. I receive some calls fine, other inbound calls cause the entire system to reboot/restart. Just started happening within the last week.
  • nykerk Apr 13, 2008
    I just set a reminder in my outlook once a month to remove the caller ID log.
  • Anonymous Aug 01, 2008
    Clearing the caller ID worked. I thought I was going to have to buy a new phone. Thanks for your post.
  • Anonymous Mar 25, 2014
    SIEMENS C450 DOES NOT RING FOR INCOMING CALSS. THE "MESSAGES" BUTTON LIGHTS UP TO SHOW THAT THE IS A MESSAGE COMING IN.
I have a Siemens 8825 and it was rebooting too. Clearing the call log fixed the problem.
Posted on Aug 14, 2008
I have the same problem with mine - a Siemens 2420 base. The calls come in, all the lights flash, then the thing clicks and resets. At this point, it can only be used for outgoing calls. i think i'm going to retire it. Too bad, cause the speakerphone was one of the best ever.
Posted on Apr 13, 2008
  • dheartglass Apr 13, 2008
    my previous post should have been a comment, but i found the solution to this problem by searching a bit on google:
    It seems that this phone has a bug that affects it when the caller log gets full. It's either a result of the full log, or a particular number in the log, but regardless, if you delete all entries in the caller log, the phone works perfectly.
    Also, i modified my setting so that no numbers are stored to the log anymore.
    for more info on this, see the page where i found the solution:
    http://press.teleinteractive.net/yackity...
SOURCE:
Message light flashes continually; some incoming calls can't get through.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
As for incoming calls, are they possibly going to the aforementioned voicemail system?"
Jun 19, 2013 | Siemens Gigaset S455 Cordless Phone
Message light flashes all the time. Sometimes incoming calls won't work.
Siemens gigaset 2420 two line phone drops calls
dump the memory by deleting your mailbox and your call log-
Feb 15, 2009 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset 8825 Dropped Calls
We use the same system for our home office and when ours went bad we sent it (and a bad handset we had) to www.cordlessrepair.com We got the rush repair service and got them back in a couple days. It was cheaper than buying a used one, my display was going bad too which they took care of at the same time and put in a new display, but it did cost me a little more. We love the phone so its worth it, and we looked for something similar but they all seem so cheaply made nowadays and we need alot of handsets. Hope this helps someone.
Mar 01, 2008 | Siemens Gigaset 8825 Cordless Phone
Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Nov 14, 2007 | Siemens Gigaset 2420 Phone
Siemens gigaset A410 problem with some hardware
Your unit got hit by a lighting strike, but it is fixable. Go to www.cordlessrepair.com
Oct 31, 2007 | Siemens Gigaset 4000 Phone
Siemens Gigaset 8825 Cordless Phone Logo
780 people viewed this question
Top Siemens Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
