Noisy phillips TV model tr 2503 c121
My phillips tv makes a constant, low level buzzing or humming noise, any ideas what imay be the cause?
Mine does this too, just bought it yesterday and noticed the sound this morning, I guess because the house was quiet, now it's the most annoying noise ever. I have been searching for solutions all day, one forum said to go to the picture settings and turn the light sensor to "OFF"...Haven't gotten home to try it yet, but I hope this helps BOTH of us!
Posted on Feb 15, 2010
My phillips is making a loud buzzing noise, no picture, then it shuts off
presuming it has one two choices: contact Philips (good luck there) or Google the model number with "color wheel"
Oct 31, 2012 | Philips 50PL9126D/37B 50" DLP TV
Constant buzzing noise when using dvd player, playstation etc.
If this "buzzing" sounds like a low frequency hum, then it is probably a loose or bad cable from the equipment. I am assuming you have this connected to an AV receiver or the tv. If the cables are not securely connected or is a damaged cable it causes the ground to be suceptible to "noise". That is what I would check first. Let me know if that fixes the problem, or what you did right before you noticed this issue.
Aug 26, 2010 | Televison & Video
My tv makes a low humming buzzing sound about 3/4 of the time. One quarter of the time it does not buzz. When it buzzes a line moves fairly slowly from the bottom of the screen up to the top continually....
there is a bad or what i call intermittant connection on the power supply board. when the bar and hum appears try firmly bumping with the palm of your hand the side of the set. if the hum and line go away then your set will have to go into the tv shop and the connectors on the p/s mod have to be reseated also the solder connections should be checked... this should help you a lot.
Mar 09, 2010 | Maxent MX-32X3 32 in. HD-Ready LCD...
Reference to Phillips Magnovox Model PR1302 C121.
turn on tv,it turns back off,without lighting screen.
May 04, 2009 | Philips Magnavox 27MS343S 27" TV
TV Just Started Making a Humming/Buzzing sound
Replacing a flyback is not something I would suggest for anyone with no electronics experience. Second, lets see where the noise is coming from first. Take off the back and listen to the noise. The flyback will be at one end of the large red wires that go to the tubes. Sometimes the connection at the tube is not 100% and the noise comes from there. BE CAREFUL - there are high voltages going through this red wire that can be dangerous even with the set UNPLUGGED!! IF the noise is coming from the connection at the tube, with the set unplugged, carefully turn the rubber cap back and forth touching only the rubber part with one hand. Put the other hand in you pocket while doing this.
If the noise comes from the flyback side, if you can solder, again with the set unplugged, try resoldering the pins on the transformers. That may resolve the problem.
Keep me posted.
Feb 13, 2009 | Samsung HCL5515W 55" Rear Projection...
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
Need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
The manual for the remote can be found here (as of 06/07/2009):
Jul 19, 2008 | Universal Remote Control DIRECTV Universal...
LG LC55 humming/buzzing
Have you tried adjusting the contrast? , have a similar problem with a 42'' lcd and it appears to be related to the contrast setting .If is set my contrast below 90% the buzzing sound stops.
This buzzing sound seems to be a common problem with LG TV's
Nov 24, 2007 | LG 42PC5D Television
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
Televison & Video Logo
263 people viewed this question
Top Televison & Video Experts
