Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
HP office jet pro
I have a paper jam? stuck in the feeder
  • 5 more comments
  • CANATASK Dec 06, 2007
  • rayspa Dec 15, 2007
    I have a 3 check sheet stuck in teh printer. The first check has printed but only 3/4's of it is sticking out of the top of the printer. There is no back to remove to get to the check sheet on the Samsung ML 2510 printer. What do I do?
  • yobuda Dec 18, 2007
    hp k550, removed jammed paper, printer flashes of/off and resume lights on front. there is no paper in unit, can't get it to respond other than to power up, make a small movement and flash its little lights. help, behind on paperwork!!
  • 1rea Feb 18, 2008
    Attempted to print an envelope and machine jammed with error message of open door and clear jamb.  But no door opens to where jamb is!  No instructions of how to accomplish this were included with install instructions.
  • 1rea Feb 18, 2008
    remove paper jamb
  • Anonymous Mar 13, 2008
    its saying carriage jam open door, clear jam and press ok
  • Anonymous Mar 26, 2014
    trying to find schematic drawing of Lexmark Pro750
  • 31 Answers
Posted on May 24, 2009
    Problem Solver:
  • 16 Answers
1:turn off the printer (unpluee)
2:slowley try to remove the jammed paper from the front feeder
3: if not successful locate the rear of the printer, there is a door u open it by pressing the two clatches on the left and the right once u removed the door ull find the jammed paper try to pull it gently
Posted on Nov 28, 2007
Hp officejet pro paper jam when there is not one
Type in your search engine How to fix a printer jam in an HP office jet pro YouTube
Jun 08, 2017 | HP Office Equipment & Supplies
Hp laser jet cp1525nw false paper jam
All I can say is check the paper Jam sensor for particles of paper that it is sensing as a jam.
Jan 27, 2017 | HP Color LaserJet Pro CP1525NW Wireless...
Hp office jet l7680, paper jam, however no visible paper remaining, jam indicator still flashing.
If the printer shows ready and after you send the print or copy job it gives you paper jam, then the problem is with the pickup roller.
Let me know and I will help you further.
Oct 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
HP officejet j4580 All-in one shows message on its screen"PLEASE REMOVE PAPER ON THE FEEDER OR GLASS.PRESS OK"and when i m press ok it process it in normal mode and when i going to shut down...
That suggests either a faulty sensor or there really is stuck paper... a piece smaller than your little fingernail could jam many printers.
If you can't see inside the thing, a vacuum cleaner with a blow function might help... but try that only through a filter
Nov 06, 2017 | HP J4680 Office Jet All-In-One Printer
Feeder jam in Hp office jet 7650
Can you see any bits of paper sticking out anywhere? If there is no paper simply re-seat the ink cartridge and perform a complete power cycle.
Jun 20, 2011 | HP Office Equipment & Supplies
Printer HP Office jet Pro K5400 Paper jam happened now we cant print anything. Orange button with ky just keeps flashing. Can you help please?
This typically means there is still paper stuck somewhere in that. My guess is that whatever paper as removed tore as it was pulled out. Look carefully everwhere you can.
Friendly, Inexpensive, REMOT Computer help!
Nov 23, 2009 | HP Officejet Pro K5400dtn Printer
When trying to use the scanner to make a copy of a document. The paper jammed, how do you remove it? It said on the glass window to remove the back where the ink containers are. I did that but I cannot see...
There are possible 2 places for the paper jam, either the Feeder has jammed or from the input tray.
For Feeder, you just have to open the feeder from the top and see if there are any pieces sticking in.
Else, you can open the print head cover and look for pieces of paper jammed in it.
Another place you may see is by removing the rear of the printer, it is called a duplexor which can be taken off easily. You may find some bits of pieces in rear of the printer.
To avoid getting another jam, try to keep the paper in a cool and dry place. If the paper absorbs any humidity, it starts crumpling which results in paper jam. You can also try fanning the papers before putting in a bunch and use a recommended paper for the printer.
Hope this helps.
Oct 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Paper jam in auto feeder
Well you should be able to pull out the whole sheet of paper. If the jammed paper has a piece missing, then you did not clear the jam completely and will have to in ther and retrive the torn piece of paper.
The source of the jam can be a worn p/u roller or an obstruction in the paper path.
Jan 06, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
