Question about Performance Teknique ICBM-774 Car Audio Amplifier
I would like to get a user manual for this amp or get informed on how to wire itr so I get the 1000w that it is rated at. I have sony 10" subs in a custom box for a titan. I just recieved the box installed my speakers and it just does'nt seem to hit as hard as it did befor the box change. Any help would be greatly appreciated.
  • 1 more comment
  • Titan07 Nov 29, 2007
    Yea no thanks, unless you want to send me 10 bucks
  • Anonymous Aug 07, 2008
    how doi geta owneres manual
  • bullet sfv Feb 18, 2009
    i need the manual please!
  • 709 Answers
It is almost obvious to me that the New Box is Unvented. If you went from Vented to non-Vented. there you go. The Amps and Subs should be doing the same thing. If your Sony 10's are designed for Vented they will not thump right in a NON-vented box.
Posted on Nov 30, 2007
SOURCE:
I need a user manual for a performance teknique ICBM- 136
Try Googling (Performance Teknique)(ICBM- 136)(manual) without parens.
Aug 15, 2017 | Performance Teknique Car Audio & Video
Installation-wiring
Performance Teknique might be able to supply a manual and/or wiring instructions.
Jan 01, 2014 | Performance Teknique Icbm-7348 Cd Mp3 Wma...
Proction light stays on
If it stays on even when the speaker are not connected to it then the amp is fried but f it goes off when the amp is hooked up with no speakers then check the Ohm load on the amp and wire the speakers to match that but don't go below the ohm load on the amp...this site will help.... http://www.crutchfield.com/S-ApB0sVuYqNs/learn/learningcenter/car/subwoofers_wiring.html
Aug 13, 2011 | Performance Teknique ICBM-774 Car Audio...
Red lightstays on no power how to fix
Sounds like something is shorting out and it is protection mode. Check that the wiring is correct and there are no bad spot on the power wires
May 25, 2011 | Performance Teknique ICBM-774 Car Audio...
Tengo un performance teknique 774 yse apaga cuando le sibo volimen
Si dos cosas bien importante deves acer primero es la entrade de tierra debe estar en buen metal,segundo que no este interferiendo ningun corto falso.
Jan 04, 2010 | Performance Teknique ICBM-776 Car Audio...
I lost user manual for Performance Teknique ICBM-9493TV Car Video
Yo I have a icbm 5254 in dash monitor and in order to bypass the parking brake security, splice the wire that's marked "park brake"(mine is Pink, yours may be Orange,but it'll be the oddball colors) into the acc or aux wire(usually yellow) and it'll play dvd while moving. Hope this has been helpful.
Feb 28, 2009 | Performance Teknique ICBM-9493TV Car Video...
Performance Teknique ICBM-779
You may have a defective speaker or a wiring fault. Disconnect the speaker from the amp and measure the resistance across the speaker wires. The resistance should be near the rated impedance of the speaker.
Jan 27, 2008 | Performance Teknique ICBM-779 Car Audio...
Wiring question
Hi, If I got the specs right, your amp is a 4 channel hence the 4 RCA inputs. Probably the simplest would be to feed the 2 X RCA out of the deck to the 1 & 2 RCA in of the amp. This amp has also a line out, feed the amp's lineout back to the 3 & 4 in. This way, all four channels get same input from the deck and you will have identical power to all 4 speakers (front & rear). An afterthought is to also use the 4 outputs of the deck (since they are there anyway and it is not a good tech practice to leave outputs without load/speakers) and connect 4 mid-range or 4 smaller speakers. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Sep 02, 2007 | Performance Teknique ICBM-774 Car Audio...
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Performance Teknique ICBM-774 Car Audio Amplifier Logo
475 people viewed this question
Top Performance Teknique Car Audio & Video Experts
Mike Duncan
Mike Duncan
Pierre Laplante
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
