My receiver does not have a specific sub output. Are there any other RCA connections that could be connected to a powered subwoofer to feed the signal to the sub. My receiver does have a tape monitor which I have an equilizer currently connected to. Are there any options to connect the sub via RCA with what I have instead of using the speaker wire connection method?
Comments:
Nov 28, 2007
- You know, I feel like an idiot after really thinking about it. Should've done that before I posted I guess. After reading other similar threads, guess the only way is through speaker wire connections. Line level is just that...level...no change in volume with the rest of the system....that won't work! No need to reply, got my answer. Thanks.
front right audio out has noise. is it a loose wire inside, or a broken piece inside? Basically I...
(More)
front right audio out has noise. is it a loose wire inside, or a broken piece inside? Basically I want to know if it's very expensive to get it repaired. or is so simple I can do it myself.
Hello,When the amp is turned on there is no sound the amp has been fine up until now what should i...
(More)
Hello,When the amp is turned on there is no sound the amp has been fine up until now what should i check?
Just installed cable to denon avr-3805 and the sound from the speaker us very low and will not alter...
(More)
Just installed cable to denon avr-3805 and the sound from the speaker us very low and will not alter the speaker works ok in the tuner mode but not DBS mode
5.1 signal is not being amplified. blu ray player decoder is working fine. if i connect the cinch...
(More)
5.1 signal is not being amplified. blu ray player decoder is working fine. if i connect the cinch into an other input (e.g. cd player), i can hear the signal. only the 5.1 input stays quiet.
what is the reason?
I have a dish vip722 and a Yamaha rx-v663 receiver. When I try to program the Dish remote I used a...
(More)
I have a dish vip722 and a Yamaha rx-v663 receiver. When I try to program the Dish remote I used a 823 code. I also tried all other codes in the book. It all works fine except I can't turn the rx-v663 receiver off with the power button. I can turn it on and use the volume however. The rx-v663 has a power buttom and a stand by button..I think this may be the problem but I am not sure if there is a way around it or not. Any help? thx Ken
