Question about Brother MFC 240C All-In-One InkJet Printer
Does not accept black ink cartridges
My Brother MFC240C will not accept new black ink cartridges. All the readout says is: No Cartridge, open ink cartridge cover, then reinstall ink cartridge. I have opened three new cartridges and tried over and over and over again to no avail. What can I do? HELP!!!
  • 1 more comment
  • ShetlandRose Nov 28, 2007
    Thanks very much. I figured it was something major, as it registers "no ink" in the new cartridge levels. Guess that MFC-240c is another throw-away machine. At least I can still make use of the scanner. Thanks again for your help.
  • Anonymous Feb 04, 2008
    From ShetlandRose: I unplugged the MFC-240C machine from November 28, 2007 until last week (2 months) when on a whim I powered it back on. Odd. It did an automatic ink cleaning and then the printer worked fine -- until -- the black ink ran out yesterday. Once again it is locked into the "no cartridge" business. What do you think? Can I reset the entire machine or something?
  • Anonymous Mar 20, 2014
    suddenly wont accept 3 ink cartridges
  • 832 Answers
Did you use generic ink? These generic carts are different (no seal to prevent staining). This carts stain the led control circuit board which has to be replaced by a new one (the spare part is only avaiable as the whole ink cart holder incl. led board and tubes).
There is no way to do a short fix, sorry!
Posted on Nov 28, 2007
  • Mix-it-up
    Mix-it-up Nov 28, 2007
    No. Give it a try at eBay ;-) or better call brother hotline and ask if they are willing to to repair in guarantee.
Brother mfc240c not detecting black ink cartridge. When I remove the cartridge and replace it with another it will not detect that the cartridge has been removed.
on the ink cartridge, midway between the two holes that plug into the printer, there's an opening. evidently, the printer senses ink level thru the little piece of plastic.
with printer OFF, take all ink cartridges out. cut small pieces of duct tape, small enough to cover the hole but not pass the catridge edge. use a small screwdriver or tip of a knife blade to work the edges of the tape into the slot, covering the little plastic window.
insert back into printer. worked for me. it's simpler than it sounds.
Jul 27, 2010 | Brother Multi-Function Center MFC-240C...
How to change ink cartridge? mfc240c
The four ink cartridges on the Brother MFC-240C are located on the right side of the printer. Pull open the gray cover (there's a tab on the right side) and then you'll see a purple handle for each cartridge. Pull out the handle for the cartridge you want to replace, slide the cartridge out, then slide the new cartridge in (after removing it from the packaging and taking off the yellow plastic cover).
Once you insert the cartridge so it snaps in place and close the cover, the machine should recognize the new cartridge.
Apr 15, 2010 | Brother HL-2040 Laser Printer
I installed the black ink cartiage but the printer still says black ink is empty. I have a brother multi-function center mfc240c
I had a similar problem, but my problem stopped when I changed back to the Original Brother Cartridge. After you open the black lid, take the black out and wipe it clean. The well that is. They dont work well with Generic.
Let me know okay?
Good Luck :0)
Nov 11, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc240c will not print
Are they genuine Brother ink cartridges? Some Brother models won't accept generic or non-OEM ink. Try replacing them with genuine Brother cartridges.
Oct 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
MFC does not recognise the new black ink cartridge.
Disconnect power supply and USB lead (leave disconnected for 10 min). Repeat this for each colour that is not working and hey presto the LCD readout will revert to normal and you will be able to print again. Happy Christmas! Hope this works for you (worked for me)
Dec 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Put a new black ink cartridge the model mfc240c will not let us print says color cartridges are empty but we only want bkack and white print why wont it work
Most likely because it uses color as well with the black. Some printers will not allow only 1 cartridge. You need both.
Thanks and keep me posted,
Lee
Jun 17, 2008 | Brother Office Equipment & Supplies
Brother MFC-420CN All-In-One Won't accept Ink Cartridge Replacement
you may be able to reset the ink cartridge detector, in the printer software, so that it detects the new ink cartridge.
however Brother printers do not handle generic ink cartridges well
good luck
Terry
Mar 15, 2008 | Brother MFC 420CN All-In-One InkJet...
No ink display on brother mfc240c
First make sure that you are using Brother Cartridges, their machines are very sensitive to using generic ink. Put a brand new set of ink in the machine. Pull all the old cartridges out and put all new cartridges in. If this does not resolve the issue contact Brother, they are very good about helping their customers.
Jan 02, 2008 | Brother Multi-Function Center MFC-240C...
How to refill the cartridge of brother MFC240c
Hey its very simple, you'll need a syringe and an exacto knife. You just need to pop the case in half use the exacto knife to cut the seem very carfully and to pry the cartridge apart carfully. On the back of the cartridge you'll see a little indintation were it was filled in the factory just fill the cartridge with a syringe push in the indintation fill cartridge remember to leave a little air in there and seal the hole up so it's air tight again this can be done by using a little hot glue to seal the hole. I hope I was helpful. As well you can by a continous ink system for the brother 240c which is pretty need too
Sep 08, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
200 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
