Question about Sony Cyber-shot DSC-H2 Digital Camera
Lens conversion I often use a telephoto lens or another type of lens such as a panoramic. I cannot get my camera to switch back to normal lens usage. I do have the Conversion Lens: OFF in the menu option. In the screen though my camera still shows W========T there is no other. Any suggestions? Usaually there is a line between the W and the T to show zoom conversion. I cannot get that back.
    Problem Solver:
  • 8 Answers
Check the smart zoom precision zoom setting
Posted on May 10, 2008
Can I use Telephoto converter on my handycam DCR-dvd108 to shoot picture of object on moon surface? If so, what kind and feature Please?
You can't as the lens is fixed and I wouldn't have thought you needed it. It has 40 optical and 2000x digital. That is better than a home telescope. You just need a good tripod.
Specs
Carl Zeiss Vario-Tessar lens; 40x optical/2000x digital zoom
You may be confused regarding 'conversion lenses' by the text on page 64 of the manual regarding NightShot Mode, but that is infra red shooting and not like a DSLR lens converter?
https://www.amazon.ca/Sony-DCR-DVD108-Handycam-Camcorder-Optical/dp/B000M3ILF6
Your manual is here;
https://docs.sony.com/release/DCRdvd308.pdf
Oct 10, 2016 | Sony Video Cameras
Own DSLR camera would like to know the single best lens for the DSLR?
"Best" lens depends on several things:
1. What kind of pictures do you intend to take?
2. Do you mind a heavy leans? Some are 10 pounds or more.
3. Your budget.
The "standard kit lens" that most come with is perfectly good for general photography. If you want to take architectural pictures, you'll need something different. If you want wide landscapes, you will need a wide angle, and if you want wildlife/bird pictures, you'll want a telephoto lens. It all really depends on what you intend to do...
For example, I have a very wide lens I use for interior architectural pictures, medium telephoto for portraits, and a variety of long to very long telephotos for wildlife pictures...
Yes, there are some extreme zoom lenses that cover 'normal" to "very long" telephoto. They're expensive, not especially sharp, and very heavy. Everything is a compromise.
Dec 18, 2015 | Canon EOS Rebel G 35mm SLR Camera
2.55X Telephoto Conversion Lens
Some incredible or crazy mixes are always possible. (lens away from the camera, 2 lenses in series, with one in the reverse direction, etc...) Anything can be experimented. Just check the result is o.k.
Jul 13, 2014 | Cameras
How to remove moisture from a sony wide conversion lens
Put it in some Rice in a plastic bag, let sit for a cupole of days!!
Jun 24, 2014 | Sony 58mm 2x Telephoto Conversion Lens For...
Need to convert a Vivitar 70-150mm telephoto from Canon TX to Nikon FTn mounts
Vivitar made several different 70-150mm lenses. If the lens has a T-mount then you can purchase a Nikon T-mount adapter and replace the Canon one on the lens. If the lens does not have a T-mount then you're out of luck. Nikon cameras have thicker bodies than Canon cameras, and an adapter would have to have negative physical size.
Mar 16, 2014 | Vivitar Series-1 3.5x Tele Conversion...
Canon g11 telephoto lens vignette
You have to zoom the camera lens out for that lens to work.
Feb 15, 2014 | Opteka 32x HD?² Telephoto Lens for Canon...
I have a vivitar telephoto lens for the camera, but not sure how to mount the lens. If I take the outer ring off, I dont know if the lens that came with the camera is suppose to also unscrew, or if there...
None of these Canon Powershot cameras have a lens which will remove.
The ring is only for a special kind of add on lens for either wide angle or telephoto, which will only fit this camera or possibly a few other models.
Never try to unscrew the lens, you will ruin the lens permanently.
Oct 17, 2009 | Canon PowerShot A540 Digital Camera
Lens problem...
You are experiencing lack of communication between the shorter lens and the camera body. Since the longer lens works correctly the problem is in the other lens and not the camera body. BTW-the numbers 62mm & 55mm are probably the filter sizes for each lens and not the focal lengths. Unscrew the filters and you will probably find a name ring on the lens signifying the type of lens it is(e.g. 28-80 or 70-200 or something like that.) Look at the rear mount of the problem lens. There are some small metal(5-6) contacts there. Make sure the contacts are clean. If not, clean them with a soft rag or Q-tip. If they seem to be OK then there may be a problem inside the lens with the flexible printed circuit(FPC). The FPC may have been damaged somehow. If this is the problem take the lens to a competent repair shop and have them evaluate it. Depending on exactly which lens it is, it may be cheaper to replace the lens rather than repair it--but have it looked at anyway. Hope this helps.
Jun 26, 2007 | Pentax ZX-30 35mm SLR Camera
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Sony Cyber-shot DSC-H2 Digital Camera Logo
67 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
