Question about Epson Stylus Pro 4800 InkJet Printer
i have two machines that the Magenta is cloged on the lines... what could be the problem?
  • 33 Answers
Lack of use.
Posted on Apr 18, 2008
Dell 7130CDN Chattering along with lines in color image.
Pay him
and let him fix with new items
you might end up destroying the whole machine
Jan 14, 2016 | Dell 7130cdn Printer
WASHING MACHINE WILL NOT DRAIN WATER
if your machine is hi eff.it may be the pump due to the small line on the suction side something may have cloged the line
Jan 28, 2015 | Washing Machines
Lines on colored prints
Hi Jam Jam, Try changing the Print Quality from Text to higher print quality.
May 12, 2014 | Brother MFC Office Equipment & Supplies
Water line cloged
If it's one of the main fill hoses going to the machine it has probably collapsed inside, replacement is the only real cure.
Dec 29, 2012 | Frigidaire Affinity ATF7000E Front Load...
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
Epson 10600 error 30017
Request to check printer setup and connectivity. You may have to enable the printing services from Start>Run>Type services.msc
Once done, please check the startup items and for rest, please follow the link below
http://www.fixyourownprinter.com/kea0.html
Warm regards,
Anirban Mazumdar
Oct 09, 2009 | Epson Stylus Pro 10600 InkJet Printer
Error message OKIC3200n printer
I called the OKI help number, in the manual, and they told me that the second line of the error message, was just an additional reminder, to replace the magenta toner.
Sep 29, 2009 | OKI C3200n Led Printer
Epson Stylus R230 Light Magenta Not working
I would recommend cleaning the contacts (brass colored connections) with an eraser if might resolve the issue. It that does not resolve the issue it might be one of two other things. Either the printhead is cloged or the cable to the printerhead is damaged.
Good luck
Mar 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Printer won't print magenta
So what does the machine do: Not recognizing the cart (error: insert magenta) or does it not print onto the paper?
In 1# case: Reinsert the magenta cart and make sure that the support is secured above the cart top. If it is recognized: OK.
If not unplug mfc from power. take all carts out. Wait five minutes. Reconnect machine to power. wait until machine demands carts. reinsert cart as demanded and give the right answers (see display).
Machine should run a short cleaning cycle.
In 2# case: Insert full carts well. press menu then start mono (blue) then fourtimes arrow-up (te-index). machine will be in maintenance mode. press 7 then 6 then 4. machine will initialize the carts. after some cleaning cycles machine will be
in mentaenance mode again. Press 9 then 9 to leave mode. press ink etc. to run a test print. If it fails and you cant see any magenta, the valve or filter is clogged and cant be fixed anymore.
Nov 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Epson Stylus Pro 4800 InkJet Printer Logo
138 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
