Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi 55" Rear Projection - No sound and volume bar continuosly displayed
Have the TV connected through a converter box and a Yamaha 5.1 A/V receiver. One day, the sound stopped working through the TV speakers and the volume level bar is now on the screen. I've done everything I can think of to fix the problem, short of replacing the converter box. Still get sound through the Yamaha, but not through the TV speakers. Any suggestions?
    Genius:
  • 1,153 Answers
First unplug the a/v receiver and then check tv to see if the audio output is on or internal speakers. With the a/v rec. you should have chosen the variable audio and not leave on int speakers. If this does not work unplug set for at least an hour and try again. You can get additional info from www.ctechnicians.com
Posted on Nov 28, 2007
SOURCE:
How do i change my resolution to 720p on 55" inch older mitsubishi tv
Are you sure the TV supports 720p? Many older 55" RPTVs are 480 only. Even with Component. Most older component is only 480
Feb 25, 2015 | Mitsubishi WD Televison & Video
Mitsubishi tv 55 inch
Depends what kind of connection you use to connect Your Didgital converter to TV, If you provide more details I might be helpful to solve the problem. Provide the model number of Your TV. And more details what input you use and what kind of cable/connection.
Dec 15, 2013 | Televison & Video
Mitsubishi ws-55805 HDTV Control to HDMI
there is a converter box , where you can connect everything and convert in to hdmi output , you can buy this boxes on the internet or at the redioshack
Feb 12, 2012 | Mitsubishi WS-55315 55" Rear Projection...
My sound is muffled, since we put an hdmi cable on to fix the terrible picture, now we have a sound problem
This tv isn't known for sound problems. First thing to do is to go to the cable box and push the volume up button on the box if there is one. Next thing to do is to try another device that has a hdmi output like a dvd or game system in place of the cable box. My guess is that this muffled sound is somehow caused by the cable converter box. You can try to reboot the box by unplugging the power for 30 seconds, then plugging it back in. If all else fails, you can call the cable or satellite service and have them change the converter box. Good luck, Russmann.
Mar 24, 2011 | Mitsubishi WS-65809 65" Rear Projection...
How do i find the driver fo this tv so i can watch
There is no such thing as a TV driver.
In order to display PC video on a TV the PC must have a TV-OUT function and interface, or you need a VGA to TV converter box.
If your PC has TV-OUT functionality, your user manual will tell you this. If you have, Google "Display PC on TV" and you should find some good articles on how to connect the PC to the TV, and how to change the settings on the PC. NB. even if your PC supports TV-OUT, you may still need to by a converter cable (but not a box).
If no TV-OUT functionality, E-Bay lists some converter boxes from about £15. NB. the much cheaper cables only work on PCs with TV-OUT functionality.
Oct 01, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Model 55311 Can you pick up digital tv without converter box?
I am thinking that you have a Mitsubishi WS-55311. If this is the case, you will need a converter box to receive digital television signals.
I hope that this helps you resolve your issue.
Thanks for using Fixya
asnowman
Sep 20, 2009 | Mitsubishi WS-55311 55" Rear Projection...
No Audio with HDTV on Mitsubishi WS 55859; no problem w analog tv
Have had bad exprience with RCA converter boxes. The box will lose audio and has to be turned off and then back on. You may want to hit mute during this process, the volume varies from analog to DTV. If you have no problem with analog audio I would look into a different converter box.
Feb 22, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
392 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
