Question about Sharp R-1505 Microwave Oven
I removed the display panel to fix the door release that was sticking. Now, the microwave light blinks and the oven does not come on when I attempt to start it.
  • Herb33 Dec 03, 2007
    Thanks. I thought I checked that out, but I went back and reverifiied. That did the trick.
  • Anonymous Mar 17, 2014
    Any attempt to use the microwave oven by entering time or food codes always shows up as "door" code on the screen and does not allow for the microwave to turn on.
  • Sharp Master
  • 9,098 Answers
I would first suggest that you be sure every single wire got reconnected where it belongs.
Here is a diagram:
If you still have toruble, see
Posted on Nov 29, 2007
  • William Miller
    William Miller Dec 04, 2007
    4 stars, right??
Sharp R1505F front door replacement
The relevant service manuals are here and here and you can order Sharp parts from Encompass here.
Apr 14, 2013 | Sharp R-1505 Microwave Oven
Door release button doen't open the door. Can it be fixed
Dont think its too serios but best left to a pro as microwave can be hazardous if not fixed properly..No disrespect....
Apr 01, 2010 | Sharp R-1505 Microwave Oven
Broken button on Sharp R-1505 LK Microwave has the part you need for $15 delivered
Jan 18, 2010 | Sharp R-1505 Microwave Oven
I heard a pretty loud pop on my Sharp R-1505 yesterday and the microwave stopped heating. Any ideas?
get rid of it your transformer blew out they are to costly to replace and potintialy dangerous to work on unless you are trained technican
Oct 08, 2009 | Sharp R-1505 Microwave Oven
How to remove from wall for remodel project
There are 4 bolts or should be 4 holding the microwave top to the cabinet. Open the doors to the upper cabinets and you should see the bolt heads unplug the microwave unscrew the bolts while holding the microwave. After the bolts are out tilt microwave towards you and pick up from the bottom next to the wall to remove oven from mounting plate and thats it.
Sep 16, 2009 | Sharp R-1505 Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Sharp R-9h91B microwave oven stopped working
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Sep 28, 2008 | Microwave Ovens
Door Won't Close
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
You can usually find helpful exploded view diagrams and order parts for most non-Sharp models by entering your full model number here.
Aug 18, 2008 | Sharp R-1505 Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Microwave Ovens Logo
144 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
