Question about Epson Livingstation LS57P2 57" Rear Projection HDTV
Purple blotches I notice purple blotches on the the screen with certain colour backgrounds,when I contacted Epson they told me it was dust on the optical head.Does anyone know how to the optical head so I can clean it off?
  • Anonymous Dec 18, 2007
    Same Problem. The blotches are dust on some part that lies pretty deep inside the guts between the light bulb and the last lense that sits right behind the back of the screen. I took most of the tv apart to try to get the part that the dust is sitting on. I cleaned the back of the screen, the mirror and the last lens that sits right behind the screen. Did Not help. Not much help online. Epson will charge you $500 to clean it.
Ok, so I'm about to flip a lid with my TV. I am showing purple quater sized blotches all over my screen. I bought it for a discounted price because of this issue, in hopes i could fix it. I took the back panel off the TV. ( about a 6in * 6 in plate) removed the light bulb and cleaned the bulb and lens, where the light bulb faced. I used a dust cleaner and special cloth. NOTHING! I took the entire front screen off cleaned it and then cleaned the mirror and second lens.... NOTHING! Then i heard that dusk sometimes gathers behind the lens and that should be cleaned. Try this, Its 4 screws, just be careful and remember the way you took it out, because it has to be replaced the same way.
Lindsey <3 AZ
Posted on Jun 28, 2009
  • nice2talk2u2 Dec 05, 2010
    So your final attempt when you took out the lens and cleaned it behind it did this resolve the problem of the purple blotches?You never stated the end result!
SOURCE:
Printer will only print purple
on a colour printer, black is mixed with the other colours. Try printing a black and withe photo and you always get a colour cast. If your black cartridge is empty or the nozzles are blocked, you get bad colour and fussy prints.
test all nozzles, like is explained in the manual.
Check, if you know how to do, if nothing fell in the printer, that is now on the print head. Sometimes just dust or paper scraps are picked up by the printhead, making it difficult for the printer to print a normal page.
Apr 15, 2014 | Epson PX730WD Stylus Photo
Screen turns purple and images do not come out
Maryelizabeth,
Unfortunately that sounds like the CCD (screen) is bad/going out. I would contact Kodak via the guided Assistant online repair tool here.
http://support.en.kodak.com/app/repair_assist/prodfamily/default/warranty/verify/selected/true
Nov 22, 2013 | Kodak Easyshare C183
Excel Spreadsheet Chapter 2
Firstly you would need to select all the cells in the worksheet. (Assuming you have the worksheet that needs the change in format already open.)
Click on the rectangle between the row numbers and the column names ( i.e. to the left of the A and above the 1) - Marked as Step 1
Then make sure you have selected the home option on the menu bar you need to click on the bucket like button on the ribbon - Marked as BG Button. This should open the colour drop down thinggy that i added to the right of the image. Select the colour you need in this case for the purple I have marked it as Step 2 the Yellow is step 4.
To select a certain block of cells you need to click on the cell address area ( Step 3) and type the range of cells you need to select i.e. B3:B5 .. in this case its just 3 cells and can be selected manually by just clicking on the first cell and dragging the mouse to the third.
Finally jst as you selected the purple you could select the yellow colour.1_26_2013_12_31_35_am.jpg
Jan 25, 2013 | YouTube Videos
Purple or magenta dots on centre of screen ,not noticeable at certain times. EMP-TWDI
My first guess is contamination on the lens or the internal LCD itself.
I would clean the lens first, and if that doesn't solve the issue, open the unit and clean the LCD panel.
May 30, 2011 | Epson EMP-TWD1 LCD Projector
Have purple blotches all over the screen. how do you clean the dust off of the projection.
open the back and blow it out with canned air and use the vacuum hose to catch it. do not use anything on the mirrors except air.
Jan 27, 2010 | Sony Televison & Video
I have yellow and purple blotches on screen
I had this same problem on my Mitsubishi rear projection WD52527 model television. The optic engine was changed twice, and the blotches were still there. It turned out that it was the mirror inside the television that was causing the purple blotches. It was filthy and once the repairman took it out and cleaned it the discolorations were gone. Hope this helps
emmilinna
Oct 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv turns purple and green if on too long
try dusting out the inside, or maybe using a vaccum hose to get all the dust out.
Jun 25, 2009 | Toshiba 36A40 36" TV
Purple line
I think that line is from your TV set not the console.
Sep 01, 2008 | Sony Playstation 3 (PS3) Console
Everything is purple!
Hi there
Try using a different cable , should do the trick
Apr 14, 2008 | Epson PowerLite 737c Multimedia Projector
Epson Livingstation LS57P2 57" Rear Projection HDTV Logo
875 people viewed this question
Top Epson Televison & Video Experts
Steven
Steven
Level 1 Expert
janman
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
