Question about Nintendo GameCube Console
CG controller I've got trouble with my GC controller. There are four holes for the controler in the GC console, when I put the connector in the first one, the game is not responding, the controller doesn't work but if I put it into the second, third and fourth it works well, everything is ok. So could anyone tell me where can be the problem or what should I do? Is there any chance that I could fix it?? :-( Thanks a lot for the answers
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • Nintendo Expert
  • 127 Answers
Look the control jack for anything wrong or different from the other tree jacks. If damaged you would need to replace or repair.
First find a guide to dissasemble the NGC, maybe in youtube, and look for cracked or broken solders on the jack board, if you find any just solder that again and you must be done.
If your problem is a worn connector / jack, and you dont use all the 4 jacks at the same time then you may try the poor guys solution and shift the #1 jack with any of the other non so used jacks or just try to find a replacement googling.
If non working anything of previus then you may have an electronic damage on the port and that is more difficult to solve at home so no more option than letting a technician to solve it.
Good Luck...
Posted on Dec 01, 2007
My Xbox 360 controller appears to be having some issues: i turned the xbox on, and it is immediay prompting me to download an update from Xbox Live, however, I cannot get my controller connected to get rid...
There is a connect button on the controller as well. See this site or follow the instructions below. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/connecting-game-controllers.aspx
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  3. Press and release the connect button on the console.
  4. Within 20 seconds, press and release the connect button on the controller.
  5. When the lights surrounding the power button on the console stop flashing, the controller is connected.
Jun 30, 2011 | Microsoft Xbox 360 Controller
How do you use a Gamecube controller on the Wii ?
Assuming the Wii unit is situated vertically, look on the top of the unit. There should be two flaps. Lift them, and you will find plugs for four GameCube controllers and two GameCube memory cards. Plug in the controllers and go.
Bare in mind that only a very small number of Wii games actually use GameCube controllers. The controller slots are primarily for playing GameCube games on the Wii, which the Wii can do right out of the box, provided you have the controllers and memory cards.
May 31, 2011 | Nintendo Video Game Consoles & Games
I just read you post on replacing the heat controls on my 1998 Ford Contour. Thanks for the good reply. A few more questions on that, Can I replace only the selector switch DEFROST/AC/FLOOR/PANEL? Do I...
SECTION 412-04: Control Components 1998 Contour/Mystique Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 09/14/2001 Climate Control Assembly Removal
  1. Remove the radio chassis. For additional information, refer to Section 415-01.
Audio Unit
Special Tool(s) st1445a.jpg Remover, Radio
415-001 (T87P-19061-A)
Removal
  1. NOTE: Make sure the audio unit key code is available before disconnecting the audio unit electrical connectors and note the audio unit station presets.
    Using the special tool, detach the audio unit.
    • Insert the Radio removal tool into the locating holes until they click into place.
    1. Pull the tools gently to the left and right of the audio unit to release the locking tangs.
    1. Pull the audio unit out of the instrument panel.
  1. Remove the audio unit.
    1. Disconnect the power electrical connector.
    1. Disconnect the audioline/speaker electrical connector.
    1. Disconnect the antenna cable.
Installation
  1. NOTE: When installing the audio unit make sure the rear support engages on the carrier.
    To install, reverse the removal procedure.
    • Enter the audio unit keycode and re-program the pre-set audio unit stations
  1. Remove the floor console. For additional information, refer to Section 501-12.
Floor Console - Vehicles with Automatic Transaxle Removal
  1. ani_caut.gif WARNING: Wait at least one minute after disconnecting the battery cables before removing the floor console. Failure to follow this instruction may increase the possibility of accidentally deploying the air bag(s) and may cause personal injury.
    Disconnect the battery ground cable.
    • Wait one minute.
  1. NOTE: Contour shown, SVT similar.
    Remove the rear floor console screws.
    • Move seat fully forward.
  1. Fully apply the parking brake.
  1. Detach the shift indicator selector bezel.
  1. Detach the shift bezel from the selector housing.
    1. Remove three bolts.
    1. Detach shift bezel from the console.
  1. NOTE: The rear floor console must be raised to disengage the front retaining clips.
    Raise and remove the rear floor console.
  1. Remove the four front floor console retaining screws.
  1. Detach the front floor console.
    1. Set the gearshift lever into position 1.
      Partially remove the front floor console.
  1. Disconnect the cigar lighter electrical connections and remove the front center console.
  1. Remove the control opening finish panel.
    1. Remove the four screws.
    1. Disconnect the headlamp dimmer switch electrical connector.
    1. Remove the panel.
  1. Remove the climate control assembly screws.
  1. Remove the climate control assembly.
    • Disconnect the electrical connectors
    • Disconnect the vacuum harness connector.
Feb 01, 2011 | 1998 Ford Contour
Where is neutral safty switch on 83 camaro z/28
Neutral Park/BackUp Lights Switch - REPLACEMENT & ADJUSTMENT
  1. Remove the console trim from the console.
  2. Disconnect the electrical connector from the switch.
  3. Remove the 2 attaching screws from the switch and remove the switch.
  1. To install a new switch:
    1. Place the switch onto the transmission control shifter and loosely install the attaching screws. Position the transmission control shifter assembly in the N notch in the detent plate.
    2. Assemble the switch to the transmission control shifter assembly by inserting the carrier tang into the hole in the shifter lever.
    3. Install the attaching screws and tighten.
    4. Move the transmission control shifter assembly out of N position. This will shear the switch internal plastic pin.
  2. To install the original switch:
    2. Rotate the switch on the shifter assembly to align the service adjustment hole with the carrier tang hole. Insert a 3 / 32 in. (2.38mm) diameter gauge pin to a depth of 9 / 16 in. (15mm) and tighten attaching screws.
    3. Remove the gauge pin.
  3. Connect the electrical connector to the switch.
  4. Install the console trim to the console.
Fig. 1: Neutral start/back-up light switch
Hope this helps (remember to rate and comment this).
Sep 25, 2010 | 1983 Chevrolet Camaro
YT-9014A1 The four lights keeps on (not blinking) and is not being recognized by my PS3
look beneath your controller and there is a small pin hole there that looks like it has no use.put in a pin and it should reset your controller and ask you to re-connect to your console.hope this helps
Sep 23, 2010 | Sony Wireless Controller for PS3
Wii doesnt work with game cube discs
Have you got a classic controller, because this is the only way to play without the GC controller
Apr 03, 2010 | Nintendo Wii Console
Two days ago my pioneer stereo was stolen from my 96 pontiac grand am. I want to put a non tempting factory stereo back in. Will the stereo code UP3 fit with my car? Thanks.
I am not familiar with the size code that you reference, but the codes that will fit your car without modification are CG, E, GC, S, and U
Dec 17, 2008 | Jensen JER-422 Universal Remote Control
Broken GC controller
yes you can. but only though the internet.
Mar 07, 2008 | Video Game Consoles & Games
Wii classic controller
no it wont play gamecube games, but you can buy a nintendo wavebird wireless gc controller and it will play gc games and Wii classic console games
Feb 16, 2008 | Nintendo Wii Console
Red button on gamecube controller
This is simple. Just open up the GC controller by unscrewing the screws on the back. When you get to the front, take the buttons out and clean them. If it still doesn't work, that means your button pad is torn and you will have to buy a new controller.
Nov 26, 2007 | Nintendo GameCube Console
Nintendo GameCube Console Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
