Question about Sony KV-35S42 35" TV
Sound but no picture
We recently had a cable guy install a DVR with our tv. It worked great that afternoon. The next morning we turned on the tv and a picture appeared. 10 seconds later the picture shrunk, developed lines horizontally, and moved to the top of the screen until it disappeared. After turning it off and back on it either does the same thing or doesn't show a picture at all. The sound is fine. Cable guy says the signal and DVR are fine. What's wrong...how much to repair? The picture began to crunch up on the horizontal and the screen goes black but the sound is fine. Banging on the top of the T.V. several hard thumps will sometimes gets the picture back for a minute or two and does the same thing with the horizontal and it goes again. Sometimes we can get it to stay for hours at a time but once you turn it off it starts all over again.
    Genius:
  • 1,694 Answers
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Posted on Nov 28, 2007
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
I have a 35-inch Mitsubishi TV Model CK-35MX2. It is 15 years old but has never had a problem. Recently, when I first turn it on in the morning, the picture has a vertical roll until it warms up and after...
I have a Mitsubishi  "CS-3515R.  Serial number 528801. When I turn it on by remote or on the set itself, I can hear the power come on.  BUT there is no picture and no sound.  What do I do?
Oct 20, 2008 | Televison & Video
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
TV is DEAD without any prior symptoms
opening the tv you will see a fuse  it is surely open - you have to chenge with the same type and rating- pay attention to make this
just after did you disconnect the pewer cord from ac outlet- delfo
Mar 21, 2008 | Televison & Video
DVR/TV connection
With the RGB you have to run seperate audio ,I think you have ran the seperate cables for the sound but they are in the wrong place.try changing the RW from the DVR to the TV and you should get sound from them.The unfortunate truth about the HDMI is that the HDMI format has a problem effectivly communicating between components.I am a Directv certified High Definition technition and %50 of the TV's that I connect the HDMI to will not receive the signal.One trick that I have found that works is to make sure you have a picture on the RGB then connect the HDMI.Once you have these connected ,turn your TV off and unplug the power cord from the DVR for 30 sec then plug the DVR in and wait 5 minutes for it to power up then turn your TV on and switch to your HDMI input.This method sometimes works to "Jumpstart" the HDMI input on the TV .There is no guarantee that this will work but is sounds like for now this is your only option,GOOD LUCK.
Dec 29, 2007 | Televison & Video
I believe the cable guy is correct and I will suggest you call for professional help now,if you try to use it like this the problem might become expensive.
Sep 23, 2006 | Sony KV-35S66 35" TV
Sony KV-35S42 35" TV Logo
196 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
