Maytag Washing Machine - water will not shut off and overflows tub
I have an old maytag washing machine (#LAT8210AAW) which works great other than this one problem which recently surfaced. When the machine is filling with water prior start the wash cycle, it will not stop filling the tub, and is now actuallyu overflowing the tub, regardless of whether I have the load size button on small or large. Any suggestions? Thanks
  • 2 more comments
  • Anonymous Jan 25, 2009
    If the preasure switch is working properly could the problem be something else?
  • Anonymous Mar 14, 2014
    washing machine soft hum no water entering tub
  • Anonymous Mar 23, 2014
    I started a load the tub was filling up I left the lid open for like 10 minutes after it stopped filling. Now the sensing light is still flashing and the load is not starting is there a way to automatically make it start?
  • Anonymous Mar 28, 2014
    At the end of wash it say overflow
  • 164 Answers
This could be either a bad pressure switch, located behind the control panel. it has a small usually black hose running down to the tub. more than likely since this is an older machine the hose has become worn in one spot and is leaking air. replace the hose and that shold do it. if not its the presasure switch.
Posted on Nov 29, 2007
I had the same problem with our "GE Profile SensorWash" ... It would not quit filling. I took out the top 4 screws on the top of the control panel which allowed it to tip down. I saw that the pressure switch contol was on the left - it had a clear(or white) tube about the diameter of a pencil connected to the back of it. If you follow that tube down, you'll see that it connects to the lower left of the plastic tub. I simply pulled the tube from where it connects to the tub, and using my mouth, repeatedly blew and sucked into the tube several times. I could hear the switch activate each time I did this. Maybe the switch was just stuck, but for ever what reason, the machine started performing like it should! I think if it happens again, I will just replace the switch itself.
John W. - Port Byron, Illinois
Posted on Jan 13, 2008
Solution no 2 solved our problem ,also check to see the end of the pipe is attached to the drum, thats where our problem was, many thanks
Melanie, Cape Town
Posted on Aug 14, 2010
My maytag washer is overflowing and won't go into
Hello there and welcome to fixya
This is a fairly common problems on these and other machines
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please feel; free to post me back any comments on repair help or testing and removal ian installation if needed ill be glad to help you ok
Best regards Mike
Apr 09, 2012 | Maytag Washing Machines
My Maytag LAT9400 top loading washer has stopped allowing hot water to enter the tub, only cold water works. What might be wrong?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 06, 2010 | Maytag Washing Machines
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Maytag Performa water level
Jul 13, 2008 | Maytag Performa PAV2200
Washer does not stop filling and it overflows!
check the pressure switch tube connectiong to the tub for a hole or crack first
Apr 23, 2008 | Maytag Performa LAT2500A
Washing Machines Logo
2,786 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
