Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG washer doesn't work
My wahser has an error code that "LE" what does this mean? My machine does not wash.
  • Anonymous Feb 16, 2008
    I was washing a rug and got an LE code on the machine. Solution is to clean the filter on the front left lower corner - make sure to have a couple of small buckets ready to drain the water out. DO NOT TAKE PUMP FILTER OUT until it is completely drained.
My error was when the machine went into spin.
the resolve was to dis-connect the water hoses at the back of the machine. Pull out the screens (Blue = cold, red=hot) inside the hose connector on the back of the washing machine. Clean out the screens (I have a lot of iron in my well water, so this screen does get clogged). Once I cleaned these screens there was a noticable difference to the amount of water entering the soap dispenser when the machine was started. This fixed the problem.
Posted on Feb 19, 2008
    Problem Solver:
  • 6 Answers
Thermal overload protection circuit in the motor has been tripped. Let the motor cool down for 1/2 an hour then restart the cycle. If the error code is still there you should unplug the machine and have it serviced.
Posted on Dec 30, 2007
  • 31 Answers
Try looking it up in the user manual or you can try going to the manufacturer's website, look up the model and see if they have a manual or error code guide you can download.
Hope this helps!
Posted on Nov 28, 2007
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
Jul 02, 2011 | LG WM2301HW Front Load Washer
Won't spin LE is on
Apr 24, 2011 | LG WM-1832C Front Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
This means that the load in the drum is out of balance causing excessive vibration when spinning.
This means that the washer has not filled with water in 8 minutes.
This means that the motor and the control panel are not talking to each other properly
Power Failure – The power has gone out to the machine and then has come back on
This means that there is too much water in the machine
This means that the water level sensor is not working properly
The washer motor has received and over current condition
This means that your heating sensor is not working properly
This means that you had a temporary sensor error
This means that you had a temporary heater problem
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Mar 15, 2010 | LG WM2277H Front Load Washer
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
Le error code
IE means that it is taking too long to fill up.
May 28, 2009 | LG WM-0532HW Front Load Washer
Le error code on my LG washer.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Apr 25, 2009 | LG WM-1832C Front Load Washer
Washing Machines Logo
428 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
