Back to:
Tags:
NEC SuperScript 860 Laser Printer
Problem in feeding papers (by 3 users)
posted by schiang on Nov 28, 2007
I have NEC superscript 860 printer. It has been working
fine until now. The power is on but it does not feed the
paper at all. The motor seems to be rolling, but the papers
are not moving. Any idea what may cause this?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on May 11, 2008
LOCK UP WHEN PAPER STAR TO FEED
Comment by sister mario, posted on Apr 26, 2008
yes i have the same problem but i dont hear the rollers moving
Best Solution
posted on Nov 28, 2007
Thanks for Trying (70)
Lollyloopp
Rank:Wiz Wiz
Rating: 86%, 29 votes
Sounds like the pick up rollers are either dirty or are worn out. You can try cleaning them with a soft lint free cloth. Just look for a roller or wheel looking item where the printer picks up the paper. If they feel very smooth then they maybe worn out and may be replaceable. Check the owner's manual or the manufacturer's website to find out.
Hope this helps!
Rating Locked! (?) schiang has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problem in feeding papers:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
how to setup a zebra tlp2844 thermal printer print size...
Printers
photosmart c4280 print cartridgees missing/ not detected
My Nec 860 is printing with a dark horizontal line about a...
My printer has been working fine up until now printer...
The printer leaves a space or rather omits 2 or 3 letters...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
