Question about HP iPAQ H2200 Pocket PC
No Operating system
Mt PDA has jist a screen with USB at the top(because I'm connected to the PC) and the HP logo in the centre and V1.08 at the bottom.
  • 1 more comment
  • gowingj Dec 03, 2007
    Thanks. I loaded my spare PC with ActiveSync version 3.7.1. I had tried it before with no luck. This time it worked and I upgraded the Bios with the latest version.
  • titano Mar 06, 2008
    i'm have the same problem, and my pda can't be recognized by the pc....
    what can i do? the pc writes that the usb malfunctioned
  • marknlaurel1 May 11, 2010
    I tried to reinstall the ROm update but I keep receiving Eror 101: Connection Error. THis error is saying the USB from the PC to the Ipaq h2200 is not connected, but the connection is good. What can I try next?
  • 25 Answers
What you are seeing is the Bootloader screen. Sounds like you screwed up when you tried to upgrade your firmware. Try running the firmware update again or download a more recent firmware from HP. If you are lucky, the firmware update should work in that bootloader mode.
Posted on Dec 03, 2007
SOURCE:
PC does not see USB Port installing printer
Hello there and welcome to fixya
if you are sure that all of your usb ports are working properly then you can check this out
hi there, this will be a lengthy process.
please check the link below. It would have been best if we knew the exact model of your printer and what the Operating System of your pc. Good-luck
HP All-in-One Products - Resolving Installation Problems for USB Connected All-in-One Products in Windows
Source:
http://h10025.www1.hp.com/ewfrf/wc/docum...
Feb 04, 2014 | Dell OptiPlex 3010 MT Desktop Computer
Tried to update iPAQ ROM, iPAQ died in middle of Install. Help!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1.) Make sure battery is charged
2.) Locate the rom you want to use
3.) Remove machine fro cradle
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your PDA in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Highlight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from your Vendor in step 3.
10.) The PDA should now begin Flashing the iPAQ's ROM BIOS.
Aug 21, 2009 | HP Computers & Internet
Black screen after microsoft logo
Pls reintall the Operating system as the boot file that are required to reach the desktop night be corrupt.............reinstallaing operating system will be the best solution.......................Sameearyan
Jan 13, 2009 | HP Pavilion zd8000 Notebook
Microsoft Money etc. Sync Problem with iPAQ hx2495b
UR SYSTEM GOT THE VIRUS SO NEWLY INSTALLED UR WINDOWS AND INSTALLED LATEST ANITIVIRUS WITH UPDATE.
Oct 05, 2008 | HP iPAQ HX2490 Pocket PC
Driver mt 6227
Drivers for Chinese phones that you can't find elsewhere, like "Cect Elink" Phones that I talked .
Now can Download Here
1. Chinese "MT6227" USB Modem Driver
USB_Modem_Driver.zip
It should work with other models:
ZT6618 PDA, i-tv v10, MT 6227 PDA, ZTC Pocket PC 678, NcKIA N77, N82, Tecno T-880, NOKIA N99.
PC Sync Manager
MT6227.zip
Jun 24, 2008 | Nokia N95 Cellular Phone
Modem Drivers for chinese mobile phone MT 6227 and Mt6228
You can download your modem driver from here
http://www.filebuzz.com/findsoftware/Download_Mt6228_Modem_Driver/1.html
May 18, 2008 | Cell Phones
Installing this PDA on Windows Vista Home Premium laptop
you shouldnt need a device driver for your pda to work along side with Vista, as Vista has it's own Windows mobile device centre which should run as soon as you connect your pda to a usb port. If it doesnt run, then open up windows mobile device centre in programmes and check the mobile device settings as to whether usb is set to connect to the centre.
Jul 03, 2007 | Sony CLIE PEG-T615C Handheld
The Screen is back and it won't charge
Hello, it isn't that simple as a broken charger. Try the following thing. Connect battery to the PDA, check that the battery LID is connected FIRMLY to the body (there is a contact there that woun't allow the PDA to start if the lid isn't connected properly, you may want to check it too, look carefully for a small black thing and check that it can be pressed). Then connect the pda for half hour to the charger, even if no light or amber led is flashing. Then make a master reset as showed here and connect the PDA to a usb sync cable with your computer. Press simultaneous the soft reset and the power button, then press only the soft reset button. The PDA should start. If not, there is a problem with a DC converter component on the mainboard or the connector I was talking about before. Even if the charger is broken, your PDA should power on from USB cable. Good luck, feel free to ask further questions and always remember to rate replies received from this site :)
Feb 27, 2007 | HP iPAQ H2210 Pocket PC
HP iPAQ H2200 Pocket PC Logo
427 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
