Question about Genius HS-02N Headset
How do i open the speaker holder???
My headset fell to the ground and one of the speaker holdes is making werid noises, it seems that the left speaker is no longer attached to the inside, so can anybody give me some instructions about how to open the case without damaging the surface??.
0 characters
1 Points
Sound Still Play through Speakers when Headset Connected
Most computers will only pair this earpiece as a headset for voice calls. You need to make sure the headset is paired with your device as both a phone headset and media headset. Check your settings on your computer or smartphone to make sure it is paired properly to play media sound.
Apr 13, 2014 | LG HBS-700 Bluetooth Headset
Motorola H19txt has very poor sound quality
sadly you have poor quality loudspeaker. the only thing u can do is plug in a powered speaker set into the headphone socket.
Nov 20, 2013 | Motorola Mobility H19txt Universal...
The left headphone on my Plantronics Gamecom Pro 1 headset seems to not be working. Occassionally upon plugging it back in (it is USB), both headphones will work, but then the left one seems to cut out...
Most headphones are sealed by clips located underneath the foam (on the ear things). Stick a paperclip or xacto knife into the hole to unlatch the clips and then pry it outward. However, check the cable for any obvious breaks before disassembling your headphones.
Dec 31, 2010 | Plantronics GameCom Pro 1 Headset
I need rechargeaable battery for wireless sony stereo headphones mdr-rf860r
Since many Sony headsets use the BP-HP550-11 battery pack, I assume your battery pack is the same. If not, I assume whatever battery pack your headset came with, it is some type of plastic holder that holds two batteries together. Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
Nov 19, 2010 | Sony MDR-RF960RK Consumer Headset
Hi. Can my SBH500 BT Headset pair/connect to a PC? I have tried but the computer doesn't seem to 'find' the headset
Make sure the headset is put in pairing mode, to do this, turn the headset off, hold the phone button(big silver round one on the right speaker), then turn the headset on. Hold the button until the blue light goes solid. At this point, your computer should be able to detect it. Be aware, though, that support for bluetooth audio on computers is weak at best.
Jul 11, 2009 | Samsung SBH500 BT Stereo Headphones...
Left ear doesn't pick up sound
sounds like you have a break in the cable or a bad solder joint on the product if new get a refund
Jun 13, 2009 | Logitech Precision PC Gaming Open Air...
Bose Aviation headset Series 2 has high-pitched squeal.
Try wearing the headset the "wrong way". The left side of the headset on your right ear & the right side of the headset on your left ear. I have the QC15 with the same problem and it worked for me. Good luck!
Jun 03, 2009 | Bose Aviation Headset X Headset
A Bose headset is buzzing
The speaker in that Ear Cup may be blown. You should consider replacing the set with a newer one.
If you listen to this with that static noise you risk serious injury to your ear.
Jan 04, 2009 | Headsets
Silent Headset
You may have your phone on silent.
Apr 25, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Only one speaker on hte headset is working
Even I have encountered the same problem with Logitech headset.Also my microphone is not working at all.
I thing I noticed that when I tilt the cable connected at the end of microphone towards the other direction both the speakers work as I hold the cable in that position.But when I release the cable only one of them works.
Jan 05, 2008 | Logitech 250 Headset
Genius HS-02N Headset Logo
16 people viewed this question
Top Genius Headsets Experts
Tony R.
Tony R.
Teet Bergmann
sonic boom...
sonic boom...
Are you a Genius Headset Expert? Answer questions, earn points and help others
