Akai LCT3201TD 32 in. LCD Television TV/DVD Combo
Problem for Akai LCT3201TD 32 in. LCD Television TV/DVD Combo
TV won't turn on
By tutu_star_10 on Aug 10, 2009
TV won't turn onthe red light just blinks when I push the power button.
Solution #1
posted on Sep 16, 2009
Not Rated)
codehunter
Rank: Master
Rating: 92%, 13 votes
I think this might be bad/swollen capacitors, or something odd in the +5VDC circuits of the power supply, but I am posting all of the things I have found so far with these TVs.
Here are few possible solutions:
If you have no red light and you have a Megmeet MLT386 power supply, check these parts:
1) Swollen caps on the secondary circuit (may cause the red light blink problem).
2) Blown fuse F1 (5A/250V) this is caused by a shorted FET at QA1 (20N60), you may also find that SMT cap CX23 is burned up (.001uf) which is in parallel with diode DA2 which may be damaged/shorted, replace these components.
If the power LED goes from red to green when powered up but no picture, then it might be lost +24VDC from the power supply:
3)Check fuse F2 (3.15A/250V, I put a 5A in), if it is blown, replace FET at QA2A (9N50C), replace QA2 as well (9N50C). Check SMT resistors at R233,R234,R235,R236 (.47 ohm). If open, replace with .1 ohm 1W or 2W resistor (easier to source). Also replace SMT transistor QF1 (2X4 or 2N4401 NPN transistor). And replace diodes at DS2 and DS1 (HER207), DS2 was shorted, DS1 was ok but I replaced it anyway.
I dont know as much about the Megmeet MLT169A, but it has similar problems and similar components.
4) I had to replace all of the capacitors in the secondary circuit (there are six in a 3x3 row marked EC9 (1000uf35V),EC10(1000uf35V),EC14(470uf35V) and EC18,EC19,EC20 (all 1000uf35V).
Comments:
Sep 21, 2009
- OK for the Megmeet MLT169A with red flashing LED when turned on I found that IC7 was bad. This is an SMT component on the solder side of the power supply. It is a 4407P (P channel 30V MOSFET). For testing purposes, we jumped across it to feed +5V to the TV permenently instead of allowing +5V to go into standby.
Was this helpful?
Yes
No
Popular Solutions for Akai LCT3201TD 32 in. LCD
Questions and Unsolved Problems for Akai LCT3201TD 32 in. LCD
Do you recommend Akai LCT3201TD 32 in. LCD Television TV/DVD Combo?
Answer
Answer
our tv has sound but will not light up. the power switch went out and we have used the one in the... (More)
Answer
It will not turn on. it goes back to red and stays green for 3 seconds.
Answer
turned on the tv, sound & picture came on, then everything went off and the red light in... (More)
Answer
Our picture pops and goes off when turning on t.v. sometimes if we unplug it and plug in back in it... (More)
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
