Question about Linksys Wireless-G WRT54GX Router (WRT54GX2)
Slow web page loading
My web pages are loading pretty slow now. It was always very fast. I do not have my wireless secure. Can you show me how to put in a password and secure it?
  • hicky2 Mar 19, 2008
    cleared browers and temp files reset modem and router so far
    Novelist:
  • 173 Answers
To setup and improve your wireless network’s signal, you can change your Wireless Network Name (SSID) and/or try using a different channel.
Changing your Router’s SSID and Channel
Step 1:
Access the router’s web-based setup page.
Accessing the Router’s Web-Based Setup Page
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router’s IP Address ("192.168.1.1" is the default IP of most Links-ys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router’s password ("admin" is the default password), then click OK.
Step 2:
When the router’s web-based setup page appears, click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID) and if it’s still set to ‘linksys’ change it to something unique then click Save Settings.
click the Wireless tab and select the Wireless Security tab.
Step 3:
Select WEP under Security Mode.
Step 4:
Select any number on the Default Transmit Key field to determine which key you’ll be using. In this example, we selected number one.
Step 5:
Select 64 bits on WEP Encryption
Step 6:
Type a wireless network password of your choice such as “MySecretKey,” then click Generate.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 10 characters.
Step 7:
The result will be a string of random characters. Copy the resulting string since this will be the key to your wireless network.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
And click save settings..
Posted on Dec 06, 2007
SOURCE:
I would like to put a lock on the router cause signal is slow with router, when not wireless it is fine, otherwise very slow.
I assume you are talking about putting a password on your wireless router?
Type in: 192.168.1.1 in your web browser, this will take you to the router configuration page. enter the username ans password, if you haven't changed it, they will both be "administrator"
From this page select wireless security
Simply follow the on-screen instructions from there :)
May 26, 2011 | Computers & Internet
I have many times tried to set up my DWL-G730AP Wireless Router with no success. I have typed the url http://192.168.0.30, but keep getting a list of web pages so I have to use my system without security...
This is the correct address to log on to your router. 192.168.0.30 so i dont know why you are having problems.
Try to reset your router (press and hold the reset button for 30 seconds) and then follow the guide i found here, give the page a minute to load, it is fully illustrated with pictures, so is a little slow to load up
http://www.scribd.com/doc/14641796/DLink-DWLG730AP-Quick-Start-Guide
Aug 13, 2010 | D-Link AirPlus G Wireless Range Extender...
I have Toshiba Satellite A100 running Windows XP and connecting via wireless to D-Link DIR-615 router. I can get a connection and access the internet but the pages take ages to load. I also have two...
You have a slow computer. To speed up page loading you might want to add an ad blocker to your browser to speed things up since the ads take up memory resources and slow down your computer.
Aug 23, 2017 | Computers & Internet
I've been having trouble loading some pages pretty much since we've had this router. Images seem to be slow to load on most pages, I have to refresh the page several times to get youtube to play, and...
After carefully considering the problem, if you are saying that your computer loads the pages perfectly (fast and clear) when it is set up directly to the modem, then it has to be the Wireless component of either the Modem itself or your Computer.
It can also be interference with other wireless gadgets within the home.
If it is a Laptop you are using, you may wish to purchase a Belkin wireless booster to boost the signal.
If it is a PC Desktop you are using and there is no reason that it can't be connected via an ethernet cable, then I would suggest connecting it directly.
Ethernet cable is shielded cable which is designed to omit interference.
Whilst wireless is great, it is not always the answer (especially if there are other devices which are conflicting with the signal).
I hope this information is useful. Regards,
Feb 10, 2010 | Belkin F5D7234-4 Router
Slow and unresponsive internet when using a router
it could be a DNS issue. assign static DNS of 4.2.2.2 and 4.2.2.3 in ur w/l network connection properties. otherwise try updating the firmware of the router.
Jan 12, 2010 | NetGear WGR614 Wireless Router
How do I set password so people cant tapp into my wireless connection
you need to go to the security settings of your wireless access point and set up web key. Steps are below:
Step 1:
Access the access point’s web-based setup page.
Step 2:
Look for Wireless Security.
Step 3:
Look for Security Mode and select WEP.
Step 4:
Look for the WEP Encryption and select.
Put the desired password and remember it.
Nov 26, 2009 | Arris Computers & Internet
I have forgotten my network key
The easiest fix for this is to log in to you routers web interface and look at the "Wireless Settings" or "Wireless Security" page.
1.) Plug a computer in to one of the ethernet ports on the wireless router.
2.) Open a web browser such as Internet Explorer or Firefox
3.) in the Address bar, type the ip address of your router. Most commonly 192.168.1.1 and press enter.
4.) This will prompt you for logon credentials. Username is almost always admin password varies based on OEM and model number but i believe is the word "password" all lower case.
5.) This should bring you to the web interface. You should then look for something that shows "wireless settings" or "wireless security" under one of these your network key will be listed.
Oct 08, 2009 | NetGear WGR614 Wireless Router
Slow or no wireless speed, connection says excellent
Your router may be toast but here are a couple of things to try:
Please remember, I'm guessing here...
Before restoring to factory defaults, make sure you can get to the config pages using the rj45 (wired) ports. Do a speed test with a wired connection at http://www.speakeasy.net/speedtest/
1. try removing all security. No WEP or WPK. Also, use no mac address filtering. See if it speeds up. Go back to http://www.speakeasy.net/speedtest/ and try speed testing the wireless portion of your router..
2. If it has automatic channel selection, this may be acting up. So manually select channels. Then do speed tests at the web site (or any speed test web site of your chosing). You may find a screaming fast channel.
3. If this fails to help, use the reset to factory default button. Try setting up the router with NO security first and do speed tests. Use automatic channel selection first, do speed tests, and if all else fails, you can try manually selecting channels again. If the router works well, you might want to set up security again and retest.
4. If all this fails, buy yourself a new wireless 802.11N - (N1) router. They are screamin' fast and have better range.
Apr 07, 2009 | Linksys Wireless-G WRT54G Router
Bad Roomate
You can do that by accessing the setup page of the router.
You can follow these steps on how to change the name and put in a security.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router’s web-based setup page. For instructions, click here.
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless.
NOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 3:
Look for Wireless Network Name (SSID) and if it’s still set to "linksys", change it to something unique and take note if Wireless SSID Broadcast is set to Enable.
3698-009.png Step 4:
Click Wireless Security and take note of the current Security Mode.
3698-007.jpg If Security Mode is set to WEP:
NOTE: In this example, WEP 64-Bit is used. To know more about Wireless Security, click here.
3698-013.png If Security Mode is set to WPA:
NOTE: In this example, WPA-TKIP is used. To know more about Wireless Security, click here.
3698-015.png Step 5:
Click 3698-017.png.
Or you can go to this link. if you can see the images.
Jun 18, 2008 | Linksys Wireless-G WRT54G Router
Fast Page Loads Slow Downloads
it really depends on how far you are from your Router. The farther you go, the weaker the signal gets resulting in slower speeds. Slower speeds will not affect web page load times (they are tiny parts of data) but will definately affect download speeds. You need to be as close to the router as possible or get perfect range. You can put the router at higher elevation in the room to get a better range to start with. Let me know if this works for you.
Dec 20, 2007 | ASUS WL-700gE Router
Open Questions:
Time warner Email tech support pHoNe nUmBeR #@ {1844641\*0035} ansiya USA a Time warner Email Tech support Number +1-844\*641\*0035 register with Microsoft. Microsoft launch new seciruty only for exiting customer not for new microsoft ussers. to resolve all Time warner Email products. JCG is an American multinational company which was founded by Michael Time warner Email using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Time warner Email number, and selling of computer-related services and products. Time warner Email Tech support Phone Number Recently, Time warner Email has been named the number Time warner Email tech support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Time warner Email customer care number can be dialed to contact the certified tech support Contact tech support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Time warner Email Service Tag or a Time warner Email Get Time warner Email tech support Phone Number and Customer Services. Time warner Email is a US-based multinational tech support organization having its headquarters located in Round Rock, Texas. This tech support organization s, repairs, sells, and develops technology products. Basically, the company offers computer related products and services
Aug 17, 2019 | Microsoft Computers & Internet
Verginmedia Email tech support pHoNe nUmBeR #@ {1844641\*0035} ansiya USA a Verginmedia Email Tech support Number +1-844\*641\*0035 register with Microsoft. Microsoft launch new seciruty only for exiting customer not for new microsoft ussers. to resolve all Verginmedia Email products. JCG is an American multinational company which was founded by Michael Verginmedia Email using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Verginmedia Email number, and selling of computer-related services and products. Verginmedia Email Tech support Phone Number Recently, Verginmedia Email has been named the number Verginmedia Email tech support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Verginmedia Email customer care number can be dialed to contact the certified tech support Contact tech support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Verginmedia Email Service Tag or a Verginmedia Email Get Verginmedia Email tech support Phone Number and Customer Services. Verginmedia Email is a US-based multinational tech support organization having its headquarters located in Round Rock, Texas. This tech support organization s, repairs, sells, and develops technology products. Basically, the company offers computer related products and services
See all Linksys Wireless-G WRT54GX Router (WRT54GX2) Questions
Linksys Wireless-G WRT54GX Router (WRT54GX2) Logo
491 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
