Question about GE GSS20IEP Side by Side Refrigerator
Ice/Water Dispenser in Freezer door not working when you press the lever. Also the light dims when lever is pressed. Icemaker working fine.
  • 3 more comments
  • Anonymous Dec 16, 2007
    ice dispenser works but water dipenser does not.
  • Dougeskico Jan 19, 2008
    The ice maker makes ice. When switched to water it makes noise as if going to dispense but no water comes out. Thought maybe it was both ice and water but ice maker is still kicking out ice.
  • Anonymous May 23, 2008
    I have a GE model # GSH25SGRB. About a month ago, the water stopped coming out. Ice works fine. My husband took it all apart and blew air through the line. He also ran a weed eater cord through it because he figured there was ice in the line due to freezing up. The line was fine---water still came out, but not when he hooked it back up, so we knew there was something blocking the line---ice. Turns out, it worked, but only for about a day. We're back to no water and I'm very frustrated. I have read several other forums about the SAME fridge problem with GE's and I have a neighbor who I have heard also has the same problem with hers.....all almost 4 years old. GE should have had a recall or offered to fix this problem if they knew it occurred. We have no idea what to do now and don't want to have someone come out to fix it when it will happen again. We have had this fridge for almost 4 years, so no warranty.
  • Anonymous May 31, 2008
    Exact same as Shellyn's but works intermittently!!!!! We're trying the "Light on for 6 hours" trick right now but not confident!!
  • Anonymous Jul 27, 2008
    I am having the same problem but, I also have a clicking noise coming from a panel at the rear of the refrigerator.
  • 18 Answers
Sounds like a frozen waterline. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Posted on Jan 07, 2008
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
GE refridgerator/freezer light dims when trying to use ice maker
check the ice bin to see if theres something binding the auger up. take it out and thaw it is so.
Mar 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
GE Profile PDS22SIS ice maker problem
on the ice maker press and hold the size selector. This will put the ice maker into a test mode and it should cycle through. If it doesn't work your problem is with your icemaker.
Sgt 48
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser
Hello, If you can see the water line inside the freezer case you might try using a hair blow dryer to try to thaw it out to get water flowing again? Good Luck! Dr. Know
Nov 27, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Water dispenser is not working
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker and water dispenser
Mine did the same thing.  Other web sites said it was the motherboard.  I replaced it and now it works great.  The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at http://midwestapplianceparts.com
Sep 10, 2007 | Hotpoint HSS25GFP Side by Side...
GE GSS20IEP Side by Side Refrigerator Logo
196 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Joe Lamb
Joe Lamb
