Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag stack unit washer dryer unit
Hiya Guys,
It seems the water level per washer load is lower than it used to be, is that something you have heard of before?
  • 525 Answers
Not in the way you have described!...LOL. Seriously though, I can only discern that if you have selected the maximum water level available, then you are overlaoding it and need to remove enough items so that when the washer agitates, the clothes will circulate down and around the agitator, reappearing up at the top in different quadrants of the wash tub. This is true with any level you select. Another guideline to help choose the water level is to keep the items at or below the 3 oblong vertical hole slots in the side of the agitator. Then choose small, medium, or large water level.
If that doesn't help, then post me back with a more definitive description of the issue you are experiencing and any negative results you are having concerning the issue..
Good luck Dan!
Thank you for contacting me at
Dave E.(Illeagle)
Posted on Jun 12, 2008
Our Maytag stacking washer/dryer, MLE2000AYW, has generally worked well. Recently there is water in the washer after the clean clothes have been removed. The water can be removed by adding a spin cy
The intake valve may have debris under the plunger allowing the water to bypass the valve. If it fills up when not in use it is a sure sign of this. However, your issue sounds more like a clogged filter allowing drain water back in the drum after the cycle has ended
May 19, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Replace wax motor on neptune stacked w/d
I just recently purchased a used Maytag MLE2000AYW Stacked washer/dryer. The problem I am having is that the washer unit seems to turn on, the lights go on, fills with water, but doesn't not engage in the wash or spin cylce. There also seem to be a kind of intermittent spinning sound every five seconds or so when it is in the wash cylcle. Can anybody give me some ideas to troubleshoot for?
Mar 31, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
20 year old maytag stack, washer doesn't stop agitating
Your control board is bad. It must be replaced. It can not be repaired.
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't agitate, drain or spin
it only has one block fuse and should be located somewhere close to where the power cord comes into the washer. Go here this is what you need to check.
Mar 02, 2009 | Maytag LSE7806A Top Load Stacked...
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7804ADE Top Load Stacked Washer / Dryer
you'll need to by a sink kit at any hardware store and a sump pump , be advise at the place you buy . good luck .let me know take care
Jun 15, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
107 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
