This sounds like your player doesn't recognize the disc's format. You can either try the disc in a different player or try different discs in your player.
When your known good player shows "no disc" it means either the player has a problem recognizing the disc's format, or the disc is bad or maybe the lens has gotten dirty.
The DVD player of this system will output to a TV on either composite (Yellow jack), component (RGB jacks) and S-Video (a small round jack that looks like a mouse or keyboard connector) jack. Since the tint is off, I would guess that you're using the more desirable component or even the S-video jack. Try removing & re-seating the plugs into the jacks at the DVD and at the TV; then check the picture color. If it still is wrong, try using a different cable type - use a standard video cable between the yellow jacks on both the TV and DVD. You may need to set the TV input to reflect the use of the new jack - and possibly set the DVD to 480i or Interlaced if you used the Progressive Scan or 480P output when using component RGB video cables (Red, Green & Blue). Check for correct color.
Chances are the connection got dirty and caused the color issue - or less likely, the cable or even less likely - the DVD output has failed.
After all that fails, it's probably time to change the DVD drive inside
the player. Sometimes this is easy, sometimes not. :) I haven't been inside a 6300 but from looking at pictures, it's probably got a fully removable unit.
Of course, if you have a valid warranty, then when you're left with no
solutions that don't void the warranty, you have to decide whether to
try to pass it off to the warranty holder for repairs.
i think this means it is dying. mine started to skip and then promptly stopped reading the disks too. i was told it may be the optical lense and it may be better to buy a new one than have it fixed. my problem now is that i can't find a replacement that is not upconvert (i see no difference in the component cables vs. hdmi). i am sad to lose this player. love it.
either the disc ur inserting is dirty or the laser needs cleaning try cleaning ur laser first then the disc if the problem prosist take the dvd player back
Hi
If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service.
Good Luck!
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video?
Did you try connecting a different source? a digital cable TV tuner, or another DVD player?
sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine.
Good luck
