Question about Microsoft Xbox 360 Console
360 issue i have 2 red lights on left of power switch ive read manual it says over heating but its happening more often. Do i need to send xbox of for repair or could it b a simple dust problem
  • widdy Nov 30, 2007
    ALL OF THE RED RINGS ARE LIT UP AND IT IS HAPPENING ALL OF THE TIME
  • 79 Answers
Yeah, overheating sounds like the issue. If your warranty is still in you can send the console back to Microsoft for repair, if not then you could try an X-Clamp replacement. Read about X-Clamp replacements here http:/www.xbox-scene.com it will be an area of the 360 forums or go here to read about my own fix...
http:/www.modelshop.4t.com.
Please rate if at all useful, thanks!
Posted on Nov 30, 2007
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Two red lights flashing on my xbox 360 elite .how 2 fix problem with out sending it back 4 warrenty.my warrenty expired......
Ive herd of this silly thing to try.. to fix red lights sounds stupid but ive looked into it, Basicly you xbox gets so bloody hot it resets itself lol...
So get 4 towels and wrap you xbox 360 in them until ti overheats then leave it for 30 mins then turn it on... And if it works please send me a message!!
Thanks for using Fixya
May 09, 2010 | Microsoft Xbox 360 Elite Console
My xbox freezes and flashes red
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
Stop the heat and you will be fine.
Feb 27, 2010 | Microsoft Xbox 360 Console
Xbox360 show 2 rings
2 rings means overheat
leave it in a cold place for some hours and it should be ok
Oct 21, 2009 | Microsoft Xbox 360 Console
Will not read any disc's
Its because the dvd scanner is scratched or broken
Oct 07, 2009 | Microsoft Xbox 360 Console
2 red rings or lights on my xbox 360 after i tried fixing RROD
ok u need to leave it on for about 30 min. (u only need power cord in) when ur done with that, put it together and it should work for me.
Mar 12, 2009 | Microsoft Xbox 360 Console
360 powerblock works when not pluged but dosnt when is plugged
It is the power brick. If you are under warranty you can have microsoft send you a new one for free, otherwise a new powerbrick is around 80 dollars.
Feb 06, 2009 | Microsoft Xbox 360 Console
I have 2 red rings on my xbox 360 but i dont understand what they mean...
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jan 13, 2009 | Microsoft Xbox 360 Console
Need help
i think you need to take it back, but if you get it back together get rid of all the data you dont need from your xbox it works. and the rings go away.
Aug 13, 2008 | Microsoft Xbox 360 Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
