Question about Dayton (1UM44) Fan
Dayton 24 inch two speed fan
I want to set the fan on low speed and add a dimmer (3 speed) switch to control and lower the speed. One person said this would burn our the motor another person said it should work.....??
Can I do this without damaging the motor.
  • 104 Answers
Yes, it will work and not damage your motor.
Posted on Jan 28, 2008
I have a 3 speed fan controlled by 3 speed wall switch; fan hums on low, louder hum on medium, and high position eliminates hum but speed reduced to low. Is it the fan or the wall switch?
Check the capacitor (black box with wires going to switch) and see if that's going bad. If it's not that, take the control out of the wall and just use the pull chain to see if it runs correctly. If it does, you need a new wall control. DO NOT USE A DIMMER SWITCH!
Aug 04, 2014 | Concord Fans PB-1032-ORB ARACRUZ Oil...
Fan speed control electrical box burned up in less than 60 days need to replace it. Model: UC7067RK
Most the time when I hear of a UC7067 "burning up" it usually means the person has a dimmer switch on the wall that is supplying power. You will need to replace the dimmer with a standard on/off toggle switch or add an in-wall remote where the dimmer switch currently is. Both the UC7067 and WC-210 Wall controllers can be found at http://www.fanmanlighting.com/default.asp
Hope this helps!
Jan 24, 2011 | Hampton Bay Dryers
I bought a Hunter fan Model 21778 that uses 2 incandescent candelabra lights. Before installing it I called Hunter support to see if it was okay to use a dimmer switch for these lights (I had already...
They're right, you don't want to control the whole thing with a single incandescent dimmer. First of all, the fan-speed and the lights will all be controlled by the same dimmer setting (dim low, low fan-speed - dim high, high fan-speed) - and the dimmer's not rated to control fans anyway which can result in exactly what they said.
There is a Skylark control, the S2-LFSQ- where half the knob controls the light, the other half controls the fan. The only problem you may (and most likely) have is that in order for that to work, between the electrical box for the dimmer and the fan, there needs to be seaparate wire run for the fan, and a separate wire run for the light so that the dimmer can individual control both.
If that's a problem, I recommend the MA-LFQM-, which includes a module that you install in the ceiling with the fan. The wall switch it comes with speaks to that module, and gives you independent control of the fan and light without having to install new wiring. I have one of those myself, I've installed one in one of my friend's houses, and they work pretty well and then you don't have to worry about what wires you've got in your wall.
Jan 19, 2011 | Lutron Skylark Incanhalogen Dimmer 600w ...
Trying to install lsdc163pwv for ceiling light operated by 2 different switches. Install box is through switch with black common hot wire, red and black travelers and 2 white neutrals and grounds . New...
Found a .pdf file that shows LSDC163pwv ... it does not show wiring for LSDC. It shows wiring for other 3-way dimmers & separate wiring for 3-way fan control. This is a clue.
The Pass and Seymour download page does not load, so I can't see specific manual.
Let me provide what I know:
-Instructions might be confusing because LSDC works for both single-pole and 3-way circuits ... which probably adds a lot of extra wording in manual
-LSDC Device has single-pole/3-way dimmer (this requires 3 wires)
-Device has single-pole/3-way fan control with 3 speeds (which requires 3 wires)
-That's 6 total wires
-If I understand correctly, you just want to control a ceiling light? -And you do not have a fan? And your ceiling light is set up with 3-way switches.
-IF you are also wanting to control a fan in addition to the light, the box will need separate wires that go specifically to the fan >> your description shows that you do not have separate wires for the fan. Is this correct?
-Without separate wires to the fan, you can still control the light ... but if wires to light also turn the fan on-and-off, then the LSDC is not the right control since a dimmer for lights will not work on both fan and light.
To wire the light:
-You have identified black common wire for light (it is connected to dark-colored screw on 3-way switch)
-You have identified travelers that connect the 3-way switches
-The neutral wires seem to be twisted together at back of box.
-I think the dimmer is located on the top, and fan control is bottom?? Not 100% sure >>>
-Question: are there 3 wires that are associated with dimmer?
-If you can see 3 wires for dimmer, one of those wires should be black ... just hook that to common, and hook other 2 wires to travelers ... and see if it works. If not, keep connecting them until correct combination is found.
Tip- I read a lot of electrical part manuals, and when confused, I write out the instructions so it breaks down the information.
Oct 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
Can i control the speed of this motor with a ac light dimmer switch?
no . with out getting to complicated the motor is designed to operate at 60hz witch is the frequency the voltage is delevered to you at. A dimmer switch changes voltage (lowering voltage it dims your lights) lowering the voltage to a motor will raise the current (amps) create heat and kill the motor and probable the switch. Good news is you can purchase fairly cheap VF (variable frequency) drives that will do what ever you want word of caution running a motor at 30Hz or less (half speed) the motor will probably require an additonal cooling fan since its internal fan will be turning to slow to be effective
good luck
Oct 06, 2009 | Dayton Universal Ac/Dc Open Motor 1/5 Hp...
Can i put a dimmer switch on a floor fan? i just bought an industrial-type floor fan, but i don't need that much air movement all the time, how could i wire up a dimmer or potentiometer so that i could...
A potentiometer would overheat because when you tell it to turn the power down, it basically just runs the extra power through a heating element, which will probably catch it on fire for something that large. A dimmer switch changes the voltage that goes in, and is generally meant for incandescent lights. If you wired a regular old dimmer switch up, the motor would probably sound weird, and the dimmer switch or motor would break, possibly starting a fire. It's illegal to use a regular light dimmer switch on anything but an incandescent light socket. However, you can easily find a controller that will work. Look for a fan speed controller or motor speed controller. Make sure it's rated for the correct voltage and has an amp rating not exceeded by the fan's rating. These look like a dimmer switch but are designed to deliver the power the motor needs. See link http://www.lowes.com/lowes/lkn?action=productDetail&productId=70801-539-SFSQ-FH-IV&lpage=none
Sep 17, 2009 | Global Product Resources Deco Breeze...
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Apr 30, 2009 | Lakewood HV-18 Floor / Box Fan
I installed 2 industrial ceiling fans with 5 speed controls but my customer want the fans to rotate slower than the lowest setting. Could I install an ordinary lighting dimmer switch either before the...
A regular dimmer switch will not do what you want.  A variable speed switch similar to a dimmer but made specifically to control motor loads may do what you want.  I think it would have to be installed after the 5-speed controller because the reduced voltage may cause problems for that controller.  Maybe you should just replace the controller with a the variable speed switch.
Feb 22, 2009 | Westinghouse 78127 Industrial Ceiling Fan
Dayton (1UM44) Fan Logo
649 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
