Question about Honeywell HZ519 Baseboard Heater
Wont heat up
My Honeywell HZ519 wont come on , i have tried to unplug it still won't work
  • oupodno Nov 29, 2007
    I've had a hz-519 in my closet and when I finally broke it out tonight, it was useless. I was wondering if their was an anti-tip switch to reset, but I haven't been able to find anything. I literally just opened the box tonight, so I'm a little ticked off...
  • Anonymous Nov 22, 2008
    Power os on but no heat
    New Friend:
I had the same problem with my Honeywell HZ-519 but after cutting a hole in the back, opposite the control panel, I found the wiring burnt out at the female connector to the element. I replaced the female connnector and rewired it to the anti tip switch.
It's working!
Bill
Posted on Dec 31, 2009
    New Friend:
I found a unique way of fixing my HZ519 baseboard heater, i tried the banging on it when it wouldnt work as suggested in this thread and saw sparks inside, i have no star driver so i flipped the heater over and took a hammer and poped a hole in the plastic underneath the controls and what do you know there was a wire hanging off so i replace it and a pendulum weight type anti flip switch which was hung up so i righted it and flipped over the heater and hit the power and ahhhhh warmth... old fashion redneck git r done. good luck all...
Posted on Nov 13, 2009
    Problem Solver:
  • 3 Answers
I have an HZ519 that stopped working as well. I found that the anti tip switch is in fact a mechanical weight type if switch and not a mercury switch. The problem I'm having is that the plastic stud that the anti tip switch mounts to is melting causing the switch to come loose and fall to the bottom of the heater and therefore stop working properly depending upon the position the switch is in when it lands.
Does anyone know if Honeywell has a retrofit for this problem?
Thank you,
Randy
Posted on Nov 14, 2008
  • Alkaye Dec 12, 2010
    I have the same problem.and was able to open it up..the pendulum broke off...crummy plastic---part
    how do I refasten it to the post it broke off of?
  • 625 Answers
Anti-tip switches are pretty much a mercury type. self reset when the unit is upright. current path is from one side of the line to the thermostat. other thermostat to an internal oveload, from the overload to the anti-tip switch. other side of the switch to the element. neutral connects to other heater element wire[terminal]
Posted on Nov 29, 2007
SOURCE:
My heater is not working at all only my power supply light is on
unplug the heater. remove the screws holding the control panel, pull the control out from the body of the heater enough to get the probes of an ohmmeter onto the connections that lead to the heating element. the ohmmeter should read less than 100 ohms. if the ohmmeter reads infinite ohms (open circuit), the heating element or the connections to it ate bad. if the heating element is bad, cheaper to buy a new heater. if the heating element is okay, repair connections or control.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Dec 31, 2013 | Honeywell HZ519 Baseboard Heater
How do I bleed the line of a baseboard heater?
there is ussualy a small thumb screw in the feed pipe to the unit in qestion, just loosen it and let air and some water out.
or on your boiler there will be a bleed vave sometimes there is evemn an auto vent valve
Oct 13, 2012 | Honeywell HZ519 Baseboard Heater
Heater got tipped over now wont heat. It lights up when I power it on the display works, no HEAT. I have 5 small grandsons that live with me and this heater was quite expensive I need it to work and...
I do believe that there should be a tip switch under the feet and if it is broke off then you need to by pass the switch. You could use a small piece of dowel rod up inside to trip the switch and have heat.
Dec 13, 2010 | Honeywell HZ519 Baseboard Heater
Setting thermostat on Model HZ519
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Dec 08, 2009 | Honeywell (CT62B1015) Baseboard Heater
Heater wont heat
It sounds like the thermostat is loose and needs to be adjusted or replaced. Leave this to a professional if you don't know what you're doing. So many fires are caused by baseboard heaters.
Oct 01, 2009 | Honeywell HZ519 Baseboard Heater
Heater
Just fixed one, you will need a T-15tr driver, which is a security torx screw remover. Open back cover behind controls, check for
any lose wires. Heating element wire had become disconnected on the one I repaired. P.S. you will need an extension for the bit if it is just the bit, and not a screw driver.
Feb 17, 2008 | Honeywell HZ519 Baseboard Heater
Powers on, no heat
I have this model heater and it quit working as well. I took it apart to find that the plastic bosses that the safety switch mounts/screws to melted and the switch fell into the bottom of the heater rendering the heater useless.
FYI, The safety switch removes power from the heater when the heater is laying on it's front or back incase it gets knocked over while it is on.
This is a serious defect. These heaters should be recalled.
Dec 13, 2007 | Honeywell HZ519 Baseboard Heater
Stopped working?
Check for lint inside and on the edges, it may have blown and you need somebody to repair this, is it smoking at all?
Nov 29, 2007 | Honeywell HZ519 Baseboard Heater
Honeywell HZ519 Baseboard Heater Logo
1,551 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
