Question about Canon PIXMA MP150 All-In-One InkJet Printer
Erorr 5100 There is no paper jam, when I turn it on, it shoots out a blank piece of paper and when I go to print I get the error message.
  • Joeche Dec 04, 2007
    Flashes E then 2 on display screen .Turning it off, then on causes it to send blank paper through the cartridge.Screen then reads 1 (normal setting) but then reverts to flashing E and 2. Error 5100.
  • shaneef Dec 08, 2007
    i have the same problem and dont know how to fix. someone please help.
    Scholar:
  • 41 Answers
Try this....
Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING IT TO YOUR NEAREST SERVICE CENTER. MAYBE THERE'S A PROBLEM WITH THE SENSOR.
Posted on Feb 11, 2008
SOURCE:
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
I have an error code 5100. It started grabbing the paper wrong and a piece got jammed. I removed it and then it says error 5100. I have turned it off and on a few times and it is still there.
Nov 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Error message after copying 5100
This error takes place when a encoder sensor is dirty on a back side print head.
Jun 21, 2010 | Canon Pixma MP480 All-In-One InkJet...
MY CANON MP830 WILL DISPLAY A "ERROR 5100" USUALLY BEFORE OR AFTER PRINTING. IF I RESTART IT WILL PRINT ONCE, THEN DISPLAY "ERROR 5100." I CAN'T FIND ANY PAPER JAM IN PRINTER. HOPE YOU CAN HELP. RAY...
Other than:
1) checking that no paper is jammed in the printer (don't forget to check the rear access door for paper jammed internally)
2) holding the <On/Off> button until the display goes blank, then waiting ten seconds before pressing <On/Off> button again (to reset the unit) and
3) checking that the ink cartridges are properly installed,
if the problem persists, your Canon MP830 may require repair.
Dec 20, 2009 | Canon Office Equipment & Supplies
Hello, my Canon PIXMA IP1600 is suddenly not working and has a code 5100 erorr. What to do?
Error 5100 is always a carriage error.
first thing to do is check is check the timing strip(plastic strip wide around 1/4 inches and usually located behind the print head)
Make sure there is nothing around it like piece of paper or staple or pen/pencil etc.
Make sure the strip is moving freely and hasnt come out of the roller.
Check VERY thoroughly for any obstruction at all, a very small piece of paper can cause the problem.
Dec 01, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Printing error 5100; came in midst of printing multiple pages
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 12, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper jam under print cartridges
Stick a 9x12 piece of cardboard down into the tray to force out unseen pieces of paper.
Jan 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I850 printer error message 5100
GO ONLINE AND TYPE IN
CANON 850i PRINTER ERROR MESSAGE 5100
ENTER
ROD
Jun 19, 2008 | Canon i850 InkJet Photo Printer
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
70 people viewed this question
Clive
Clive
old marine
old marine
Ekse
