Question about Kyocera Finecam SL300R Digital Camera
Battery prob hi , i own a SL 300 R and i live in india, from where can i get a genuine battery ? Pls suggest and wat will be the approx cost of it ?
0 characters
1 Points
Pentax IST-D with 28-300 SIGMA. Has operated perfectly 3yrs. Camera over exposing. Reset to original done. Battery full simbol. Pushed 2 stops still very overexposed. Changed AE to spot no difference....
Did you cahnage your battery, some cases that battery is the cause of the error, If you try to fix such problem you will be undergo disassembling the parts, but it is theoritically hard to disassemble since many parts are very sensitive. in that case maybe i can suggest you to call for the service tech specialized in pentax camera. melnavz
Apr 08, 2008 | Digital Cameras
I don't have a charger.
You need either the AC-LS5 power adapter which plugs into the back of the camera to charge the battery when it's in the camera, or better still a Sony BC-VC10. The latter item charges up to two batteries at once leaving the camera free for use.
There are third party chargers available but I've found out the hard way that they often either take forever to charge the battery or at worst damage the InfoLithium chip inside the battery. As genuine batteries are expensive and the genuine charger costs less than a single battery it's both a gamble and a false economy to use anything else.
I hope that you've found my posting to be of use and ask in return only that you take a moment to rate my answer.
I've provided links to the BC-VC10 below and further down to the cheaper AC-LS5. I'm not suggesting that you use these suppliers, just that you use the links to give you a starting point to shop around for yourself:-
Ebay BC-VC10
Amazon BC-VC10
Ebay AC-LS5
Amazon AC-LS5
Oct 16, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
My Olympus E410 - live view is a blank blue or grey screen-
CCD FAILURE ! U can get it repaired Free from Olympus but i am not sure about India u have to call and check these type of CCD Failures are common and manufac problem in thoiusands of cameras of various brands all do it free u just call them and ask them about BAD CCD Shetala Cameras (Chennai) Mount View Apartments, No. 111, Mount Road, Guindy, Chennai 600 032 India Tel :(91) 44-4212 5148 Fax :(91) 44-4212 5158 E-mail :Worldwide repair warranty appointed members. PLS RATE ME WELL !
Jun 11, 2009 | Olympus EVOLT E-410 Digital Camera
Nikon service centres in bangalore india
Jun 27, 2008 | Digital Cameras
Izone 300 - won't keep a charge. Can I change the battery? Where do I get one and how do I do it?
I have the same problem with my izone 300. I charge it for approx. 2 hours and it says that it's done charging but the battery only lasts for about 15 minutes.
May 01, 2008 | Polaroid Digital Cameras
Camera not recognized by computer
I'm no expert on technical matters but I'd try the following: - make sure the camera is switched on and not in play mode. - are you sure it's the same USB cord for that camera? (there may be subtle differences which means it cannot read the EOS 300). just a thought. - makes sure it's in the right USB port. I think a specific USB port is assigned when you install Zoombrowser - invest in a card reader. They're not that expensive, quicker to upload photos and preserve camera battery life. Quite a few photographers recommend using these. I've got a Lexar multi-card reader which only cost £15 and I've had no probs with it. And since it can read various cards it doesn't matter which camera you use. Hope that helps.
Jun 19, 2007 | Canon Digital Rebel / EOS-300D Digital...
Camera stuck in playback mode
Hi Uday, As u described, I think that it is compulsary to replace the whole switching assy. please dont compare the rate, because component quality in US better than in Asia. this is the reason it costs too much. I suggest to go to Olympus shop for genuine repairs. good luck .....
Jul 24, 2006 | Olympus Camedia C-770 Digital Camera
PC-CAM 300 Driver installation problem
I am waseem my camera canon ixy digital 300 drivermodel no :pc 1008 problem is i search internet you solution my problem
i watting your anser
Sep 12, 2005 | Creative Labs PC-Cam 300 Digital Camera
Kyocera Finecam SL300R Digital Camera Logo
22 people viewed this question
Top Kyocera Digital Cameras Experts
Are you a Kyocera Digital Camera Expert? Answer questions, earn points and help others
