Question about Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
Just sits there saying printing when I try and copy and just sits there when I try and print reports saying printing but it does nothing but sit there!
Help
  • merhim Dec 17, 2007
    i have the same problem... The network printer was used as a FAX/SCANNER/COPIER . i dont know if the installation of a MFC8460N is source of the problem but, the MFC8440N is now allay printing on LCD : "imp. en cours" (printing in progress)... I can't acces to the printer configuration because it is in use. then reseting of parameters can't be made. the telnet reset dont change anything. the webinterface reset do not change anything...
    What is this PB ? how can i resolve this PB ?
  • Brother Master
  • 1,113 Answers
Menu * 2 8 6 4 super quick then 01, is full reset... warning all settings will be lost
Posted on Dec 28, 2007
I have a mfc-8440, 5 years old, low usage, 50% drum life, new toner cartridge. The problem is that the contrast of the printed copy does not change regardless of the setting using the path...
This is very easy to solve. Remove the drum and toner cartridge. Look into the machine where they sat. Now look up and you will see (a little aukward but its there) a glass plate the width of an A4 sheet of paper. Run your finger accross it. Look at your finger and will probably be dirty. This is the window the laser beam passes thru to hit the drum. When its dirty it does not allow enough ;light to the drum hence a weak beam and light printing.
simples?
May 18, 2011 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 Check Originals
Check original normally means that there isn't an original in to copy. If it says that when there is an original it probably means that the paper sensor is jammed in some way.
Jun 26, 2009 | Brother MFC 8440 All-In-One Laser Printer
Brother mfc 8500 is there away you can print out the counter information . like how many copies or prints have been done on it.
Try this:
Power off. Hold down the "Menu" button while you power back on.
Machine should say "maintenance"
Press "7", "7"
Slight pause and then machine will print out a report containing lots of counter information.
Press "9", "9" to exit (or switch off/on.
Jun 19, 2009 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8440 makes very loud noise when printing/copying
Very commonly a broken gear on the right side of the fuser. Replace the fuser and this will fix your issue. Let me know if you need a part number and pricing.
Dec 20, 2008 | Brother MFC-8440 All-In-One Laser Printer
Scan from brother MFC 8440 to pc
you need to make sure that the brother printer is et as the default printer
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
147 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
