Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Imperial Fabric Softener leaks out during the initial wash. I replaced the "dogs" and basically the whole interior of the agitator a few years back, but recently noticed the fabric softener level drops to empty as the washer begins to agitate.
  • Myron Pstrak
    Myron Pstrak Jan 02, 2008
    Thanks, I filled the softener bin with water, and 20 minutes later, it's still full.
    Scholar:
  • 196 Answers
With the machine off and empty, fill the softner bin with water only. Does the water level go down or stay the same.
Posted on Jan 02, 2008
SOURCE:
How remove agitator cup to replace dogears on a kenmore elite washing machine
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Feb 12, 2011 | Kenmore Washing Machines
Top of agitator with softener cup moves back and forth on kenmore washer
The problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
See the following illustrated steps to replace the "dogs"
Nov 18, 2010 | Washing Machines
Top part of agitator is loose not washing clothes correctly
Aug 30, 2010 | Washing Machines
Trying to replace dog agits of kenmore washer, how do I remove upper part of agitator to put in new dogs.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive. (I've used a 1/2" adapter for a 3/8" socket drive)
Jun 04, 2010 | Kenmore Washing Machines
Agitator is loose and won't pull the clothes down
DOESN'T
one way.
May 04, 2010 | Washing Machines
I need to remove the agitator to replace the agitator dogs but there is no bolt head to unscrew is there a special tool for this model 11022912101 series 90
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22912101&pathTaken=partSearch
look at the diagrams for the agitator, basket and tub and you should see how the top components of the agitator fit.
Mar 13, 2010 | Kenmore Washing Machines
Top part of agitator skipping
Also see the following.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=d097e9dd5c3d356e373397398c6ace36
Nov 10, 2009 | Kenmore Washing Machines
I have a kenmore elite model # 20949 and the bottom of the agitator turns but not the top
direction only.
Oct 31, 2009 | Kenmore Washing Machines
Agitator Dogs
take the cap or fabric softener dispenser off the top of the agitator. under it should be a clear plastic cap with a little handle on it. take it out. under it should be a bolt (7/16) with a rubber seal under it, take it out and this will release the agitator and you will see the plastic dogs inside the agitator.
Aug 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
We have a modle # LLR7144DQ0 - the agitator is not working properly. It is not pulling the clothes down into the water.
The agitator 'dog ears' have worn out. Very easy to replace.
  • Remove fabric softener or protective cap on top of agitator
  • Remove center bolt securing agitator.
  • Lift out agitator and replace dog ears.
Jun 23, 2008 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
168 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
