Question about Honeywell HZ519 Baseboard Heater
Heater won't come on
Heater won't come and heat up
  • Anonymous Feb 21, 2008
    I have a Honeywell Baseboard Heater, Model Nr. HZ-517, which is similar to Model: HZ-519. It was working just fine, until this morning when I attempted to turn it ON. The Power-ON light doesn't light, and there is no click when the Power ON button is pushed. No advanced warnings...
    Where can I purchase the special screwdriver needed to remove the cover of the unit, and where can I get an electrical diagram for it?
    I'll appreciate any help!!!
    Thanks...
    Gerd
    [email protected]
  • 625 Answers
Its difficult to make a homeowner an expert in troubleshooting his/her equipment if he/she has no technical background - but - I will try. First check the cord to plug connection. Is it tight? Does it look melted? Next, take the unit apart where the cord goes into the unit. Check the wiring path. Look at each connection. Look for burnt off wires at connections. Most connectors are the push on type and are mechanically fastened to the wires. if they are burned off you'll need replacement spade terminals and a crimping tool. (radio shack) has these. one wire will go through a thermostat and out to an element terminal. one wire may go through a thermodisc overload, then to the thermostat and then to the element. the other wire will definitely go straight to the element. there may be some extra connections for lights etc. if you have to take apart the heater make a diagram of which wires go where. use some masking tape with numbers written on it to make sure the wires go back to the same place you took them off.
Posted on Dec 07, 2007
SOURCE:
Why won’t my edenpure heater throw heat even though I changed all the heat elements
It could be a fuse. They are small look kinda like a metal diode. Unplug heater, disconnect one side of power wire and do a continuity check on the heat strip circuit. You can also plug it in and do a voltage check on the two wires connected to the heat strip. Do this to see if you are getting voltage to the strips. Some heaters have safety switches that disconnect power when the heater falls over. It's a free swinging switch that might not have reset.
Dec 23, 2017 | Heating & Cooling
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
Jan 06, 2018 | RTO Atwood Water Heater - 6 Gal LP
check across tstat wiring on circuit board for 24volts. Test points are R and W. a call for heat should give you 24 volts across those points
Feb 21, 2013 | Goodman Heating & Cooling
Heater fan on electric fireplace not working, so heat shuts off and won't come back on. The manufacturer is Southern Enterprises, Inc., model no. FA515500TX.
Was having same problem, found the fan needed a little oil on bearings. Was not spinning up to full speed so heater was cylcing on high limit
Jan 21, 2013 | Southern Enterprises Luxembourg Ivory...
My Bosch aqua star water heater lights but won't heat my water
Unplug micro switch located on bottom of water heater if it has one
Dec 30, 2012 | Bosch AquaStar Indoor Natural Gas Tankless...
Heater only sends heat when car car is in motion
Heater core is restricted,won't make heat unless the water pump is really moving, Appears you need to put a heater core in.
Nov 05, 2011 | 2005 Chrysler Sebring Conv
Honeywell HZ519 Baseboard Heater Logo
539 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
