Question about Protron PDV-768 Portable DVD Player
Power supply for the 2nd screen ??
It says on the unit its '12v dc in',,but when I plug in a 12v dc charger,,green light on front does not go on...any ideas ?? It worked fine with main unit...I'm trying to use it with another dvd player in another car...
  • 1 more comment
  • marty1 Dec 10, 2007
    I cannot get the player to turn on. I plug up the adapter to the cigarette lighter as provided in the package and hook the DC in for both units, turn the units on, but NO POWER. Any suggestions????
  • Anonymous Apr 15, 2008
    mine second display is not turning on even using the car 12vdc adaptor or the ac adaptor which cames with PDV-768 set
  • Anonymous Mar 23, 2014
    the power supply drops down! from 12voldts dc to 4v dc
If you are not using the car power adapter that came with your PDV-768 for the 2nd screen, you are likely running into the possibility of "reversed polarity" with the power adapter you are attempting to use. This can & often will cause a problem with your unit.
Posted on Nov 29, 2007
SOURCE:
Auto xs jump starter
I was also looking for the manual. So came across this site. I have just connected a 12V 1A DC charger to the 12V DC input socket. Seems to be working fine. Both green lights are on - I seem to remember that when only the right-hand green light is on, the unit is fully charged. If I find my manual, will correct if needed.
Nov 25, 2013 | Air Tools & Compressors
How to make 12v DC power supply to power my winch
use a 12v car battery and a small battery charger... a winch draws alot of amps when in use... so you need the battery to supply the amperage ... 12v power supplies are low amperage output supplies... so will not work (inexpensively).
Mar 23, 2013 | Cars & Trucks
Connecting speakers to a pc
The 12v dc power supply is for the speakers. There should be a spot for it on them. All modern PCs use power speakers, since the sound cards have no amplifier.
Jan 31, 2012 | Computers & Internet
I have a black & decker pivot plus that will not charge. How do I know if I need a battery or if I need a charger?
Batteries are only good for about a year, if they are older than that, take them back to the store and see if they are guaranteed at all, (all Ryobi tools and batteries have a date code on them, and they are all guaranteed for 2 years, a little plug for Ryobi,) that is all I buy now days, they work great. So, to check your charger, you will need a volt meter set on 12 or 20 v dc, and see if the charger is putting out, if not, then, the cost of a new ryobi might be the same as the fix for the black and decker. That is if you use the thing, we use our cordless tools every day and charge them every night, hope this helps.
Jun 28, 2011 | Black & Decker Pivot Plus Cordless...
Cannot find the charger for my vectorlite 1.5
Hi sast.
I found this on amazon: HQRP AC Adapter Charger for Black Decker VEC119SH TYPE 1 VEC120 TYPE 1... It says that fits, but anyway contact the seller and ask.
Hope this was helpful.
enjoy
Feb 28, 2011 | Vector 1 Million Rechargeable Spotlight
Start up light flashes once and it won't power on
Most probable cause is the power supply. Look at the back of the computer, check the voltage settings located near the power cord. This will be the small red tab indicating two different settings, If your in the US it should be set to 115. Also, the power supply should run the internal fan when it is turned on.
To test the power supply try this:
Open your computer case and locate the gray box that is the power supply unit. Trace the wires from the power supply to the boards and devices and disconnect all the cables by unplugging them.
Find the big connector plugged on the the motherboard, make sure it is disconnected and short the two pins: (GREEN & BLACK) Short green pin (14) to GND (any black) to switch power supply ON, disconnect green from GND to switch OFF.
This will switch the power supply, you should hear or see the fan in the power supply spin. If you do not see the fan spinning, and your sure you have shorted the correct wires, you have a faulty power supply. If you see the fan spinning, you can now test the voltage coming out of the power supply.
Place a volt meter on the following colors to test voltage:
The color code for the wires is: Red = +5V, Black = Ground (0V), White = -5V, Yellow = +12V, Blue = -12V, Orange = +3.3V, Purple = +5V Standby (not used), Gray = power is on (output), and Green = Turn DC on (input).
Feb 12, 2011 | HP Pavilion a6110n PC Desktop
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Power coverter to scanner failure.which unit should i buy? present one 240v 50/60hz.0.4A. output 12v.dc.i.25A
I just found my Canon 5000F scanner to have a power supply outputting 3V DC instead of 12V DC. I replaced it with a 12V DC Power Supply from Tandy rated at 1.5 amps. I had the scans getting darker by the day and sometimes completely black. Now I have great scans again. Just test the voltage at the plug that supplies the scanner for a healthy 12V DC with a multimeter.
Jan 20, 2010 | Canon CanoScan 5000F Flatbed Scanner
My magellen 3100 battery will not charge
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Protron PDV-768 Portable DVD Player Logo
97 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
