Question about Ricoh GR-1 35mm Point and Shoot Camera
Ricoh GR1v, 28mm
I owned this camera for about five years. The digital display on the top of the body is fogged and I lost the lens cap but it worked fine. The other day I went to use it and it was dead! I purchased a new battery and still nothing happened. Can it be repaired? if so where? Can it be factory reconditioned? Its a great camera and I don't want to loose it.
  • Floydman Nov 28, 2007
    Night71,
    Thank you for your comments and advice. I will try to open it it up and let it dry out.
    In the event this procedure does not work, is it worth sending it back to the factory for reconditioning?
    Floydman
  • 328 Answers
Moisture and electronics dont mix. You can take it apart very carefully and air dry it for 24 hours. Sometimes corrosion eats at the solder points or causes a short between two points. If you like taking things apart, you can check and clean the board and battery compartment with alcohol and a q-tip. The biggest issue is not to try to use it until all moisture is gone from it. If you are not confident taking it apart, a service tech will do it. But just basically removing the screws and opening it can be done at home too very easily. Leave the battery out while it dries too. If the circuit board is very corroded, then there is not much that you can do except to have a professional clean it for you. Good Luck
Posted on Nov 28, 2007
  • Lyle Siemens
    Lyle Siemens Nov 28, 2007
    I am unaware that they would buy products but might give you a deal with an exchange for a newer one, since it would be hard to find one that is 5 years old. Good Luck
Can I use TOKINA lens 28mm-210 lens with this Nikon body or can I use with other NIKON body D 700?
Tokina makes their lenses with a variety of mounts. A lens with Canon mount, for example, won't fit onto a Nikon. Assuming you get the lens with a Nikon mount, then yes, you can use it with a D70 and with a D700.
Apr 16, 2011 | Nikon D70 Body Only Digital Camera
I have a canon fd 28mm 1 : 2.8 lens and I am trying to find a camera that works with it
The FD lenses were mainly for film cameras. I used this lens on a Canon AE1-P. If you have a modern digital EOS with an EF mount you can buy an adapter (FD to EF) so the FD lens can be used on the EOS
Sep 18, 2010 | Canon 28mm f/2.8 FD Lens
I need to convert my manual lens to a digital body. what digital
If you have Ricoh lenses that do not have electrical contacts, you can use the lenses on Pentax digital SLR cameras.
If you have Ricoh lenses with electrical contacts, you can not use them on Pentax digital cameras.
Jul 10, 2010 | Ricoh XR-10M 35mm SLR Camera
Is the Vivitar 21mm 3.8 a good lens for Nikon?
For what you can buy them for these days, they're excellent and were usually made by Kiron who made excellent lenses in their own name and also for Tokina and Vivitar.
But unless you're using a full frame Nikon (i.e. 35mm or the full frame digital professional bodies) then it's nothing special as it has the same angle of view as a 31.5mm lens (close enough to a 28mm for discussion purposes). A 28mm f3.8 offers no advantage over many of the kit zoom lenses which come with many Nikons and with the huge advances in optical design since the 21mm Vivitar was made are likely to be optically superior.
On balance, if your Nikon is a 35mm film SLR or a full frame sensor version then go for it as it's a fantastic super-wide angle lens. With anything else, it simply doesn't make much sense. What it will still do though is offer fantastic depth of field which will be lacking in relative terms on a 28mm lens designed for APS-C sensors.
Feb 23, 2010 | Vivitar Super Wide Angle 19mm f/3.8 Manual...
What other cameras accept Ricoh lenses? We have a great 600mm f8 lens for our 35mm SLR and would like to find a digital camera that will accept this and other Ricoh lenses. Thanks in advance for any...
Ricoh used the Pentax K-mount.
Pentax are one of only two manufacturers whose current SLR's will accept the older lenses but there will be significant compromises:-
Not all K mounts will work; there's no definitive list so it's "**** it and see".
Most KA mounts should work (KA are the autofocus versions).
All lenses designed for 35mm film SLR's will behave as if they have an approximately 1.5x teleconverter fitted: a 50mm standard lens becomes a 75mm portrait lens, a 28mm wide angle becomes a 42mm and almost indistinguishable from the 50mm standard lens. A typical 80-200mm zoom becomes a 120-300mm zoom and your 600mm becomes a rather less useful 900mm although the effective aperture remains the same.
There will be little if any communication between the lens and the body: K mounts use a mechanical coupling to transmit aperture settings to the body, and the body stops the lens down during exposure with another mechanical coupling. This will no longer work. Some KA lenses will exchange information and automatically stop down. If your current 600mm is a catadioptric (mirror) lens then this is not an issue as it will only have a fixed f8 aperture.
Your current lenses will be to a far inferior optical specification compared to modern lenses. Genuine Ricoh/Rikenon lenses were generally no match for regular Pentax models of the time, and they in turn are generally nowhere near as good as modern lenses. This is because the old models not only use inferior materials technology, but also because modern optics are computer designed and modelled and are optimised for the particular requirements of a digital imager. However, you will generally find that the actual build quality of your old lenses will be superior to modern offerings and they'll be more robust. Also, unless you regularly make large prints or selective enlargements AND regularly use a tripod you may not see the difference in optical quality in real life amateur use. You definitely won't see the difference if you only ever display the photos on a monitor.
Personally, I cannot recommend Pentax dSLR's over any other brand on the basis of legacy use alone, and if the 600mm is the one good lens then I'd seriously consider selling it as there is a demand for good 35mm lenses. I'd give the same advice whichever brand of 35mm you previously used, unless you had a lot of high-end Canon AF/Nikon lenses and were going to buy an expensive full-frame digital SLR. Look at all of the competing offerings and choose what currently suits your photographic needs.
Hope this has helped to clarify things for you, all I ask in return is that you take a brief moment to rate my answer.
Feb 01, 2010 | Ricoh XR-7M II 35mm SLR Camera
I can't remove my non-automatic 28mm from my D300
how did it went into the D300 in the first place? Hold the metal part of the lens, press the lens release on teh D300 body. Best to send it to Nikon for a look. They would charge shipping only.
Aug 19, 2009 | Nikon D300 Digital Camera
Pentax K200D Digital SLR - Error Message "f - - "
This can also happen when the lens have an aperture adjustment ring, and it is not set to the "Auto" setting ("A", on my Sigma)/
Dec 25, 2008 | Pentax K200D Digital Camera with 18-55mm...
Lens are not coming out
Did you put the lens on up-side down? Don't laugh, it happens. If so, hold the lens lock button in (on camera body)and give the lens a quick counter clock wise twist. It should snap out.
If on correctly, turn lens clock wise while pushing in lock button,then with button still pushed in turn the lens counter clock-wise.
Nov 16, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
Nikon coolpix 4500 uv lens
I bought a 4 lens kit - I think from Amazon. It was a long time ago.
The size is 28mm.
yes, here it is
http://www.amazon.com/Nikon-28mm-Filter-Set-Coolpix/dp/B0000521B9
Oct 14, 2008 | Nikon Coolpix 4500 Digital Camera
Zoom not working at all
You have a one year warranty with Canon, you should have all the information about shipping it to them in your original box.
Dec 17, 2007 | Canon PowerShot S3 IS Digital Camera
Ricoh GR-1 35mm Point and Shoot Camera Logo
278 people viewed this question
Top Ricoh Cameras Experts
Marvin
Marvin
teddyboy
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
