Question about Canon DR-6080 Path-Through Scanner
DR-6080 Scanner runs slow
Please help! Our scanner has a 4 to 5 second delay between each page that is fed. It used to run a lot faster, and we have had the rollers replaced...any ideas?
  • 490 Answers
What port are you using? May be you are using usb1.0 port. Use USB 2.0 port. Sometimes Changing USB cable would do the trick! Try SCSI if you have a card and SCSI cable, but this adds to the cost. All new comps come with USB 2.0. I had similar problem with 9080C and on changing to USB 2.0, it worked fine. Don't use USB & SCSI simultaneously.
S. Mohan, India
Posted on Dec 02, 2007
DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
S. Mohan. Chennai, India
Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
Hello, I am getting the following error message Scanner is busy, operation can not be completed. Canon DR-6080/7580/9080C Driver Version 1.3.10502.17001 (-4437) I need some assistance. Thank...
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer, reinstall drivers and scanning software. Pls run scandisk on the Computer and ensure the OS is okay.
S. Mohan
Feb 22, 2011 | Canon DR-3080CII Path-Through Flatbed...
When scanning with the native scanning software, the scanner runs very fast but file size is huge. When I use Adobe 9 to scan, my files size is much smaller but the scanner pauses after each page. I need...
I would expect the problem with the Capture perfect fike size is down to the compression chosen for the output file. Ideally black and white inahes should be Group 4 TIFFs and Colour or Greyscale should be JPEG. Alternatively you may want to check the scanner is set to 'scan ahead' in the twain settings in Acrobat. If it is set to anything else the scanner will slow down to allow the PC to process every image. With 'Scan Ahead' turned on the scanners memeory buffer the PC speed a little giving you faster scanning.
Jan 25, 2011 | Canon DR-5010C Path-Through Scanner
Hello I have the message E25 on my scanner. I'm unable to use it, do you now what that means? canon DR-6080
E25 is abnormalities in pickup motor. If you open the front/top cover, you can locate the motor, Pls check if the connections are okay. These motors are generally very reliable and don't fail.
S. Mohan, Chennai, India
Jan 20, 2011 | Canon DR-6080 Path-Through Scanner
I have a canon 6080 scanner. getting a error "no
Clean the two 'black dots' in the paper tray, just under the roller. They are actually paper sensors. Try 'page counting'. If this works, the scanner is okay. If the problem still persists, try reloading the scanning software.
Nov 17, 2010 | Canon DR-6080 Path-Through Scanner
I love my bc796d and i have had it for about 4 years? My question is concerning the delay when scanning channels and i always keep it on 4 second delay. I would like to have it delay longer and thats where...
Setting DELAY for All Search Ranges
You can set the scanner to have a delay after the end of a transmission before searching
resumes. This slows searching, but helps you prevent missing replies on a frequency.
1:SERVICE OPTION → :CHAIN SEARCH → 3:DELAY
1:NONE
The delay is turned off.
2:1 SECOND
The delay time is 1 second.
3:2 SECONDS
The delay time is 2 seconds.
4:4 SECONDS
The delay time is 4 seconds.
28
5:INFINITE
When the scanner stops on a transmission, you must press RSM to resume
searching.
6: -2 SECONDS
The scanner only stops on transmissions for 2 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 2-second pause.
7: -5 SECONDS
The scanner only stops on transmissions for 5 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 5-second pause.
8: -10 SECONDS
The scanner only stops on transmissions for 10 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 10-second pause.
May 14, 2010 | Uniden BC796D Base Scanner
IT WILL SCAN FAST AFTER 10 PAGES IT WILL RUN SLOW
Your disk must be full or you need to do a 'defrag' on the volume where you are storing the data. Initially it is stored in the buffer and when the disk writing is slow, scanning speed is affected. Clean the disk for faster scanning.
Mar 23, 2010 | Canon DR-9080C Path-Through Scanner
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
Dr 6080 4401 error code
Wht happens after the comp displays 4401 error? Does the system hang? If you can still use the comp, then forget it. Frankly I have not faced this error. But freak errors like these can be seen even if your OS files are damaged. Try reinstalling the OS in another partition. If the scanner works fine in the new environemnt, you can be sure that some files are damaged.
Dec 03, 2007 | Canon DR-6080 Path-Through Scanner
Canon DR-6080 Path-Through Scanner Logo
340 people viewed this question
old marine
old marine
