GPS Logo
Posted on Aug 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot find satellites sometimes
I have driven two years using my TomTom One and all of a sudden it cannot find satellites on some journeys. then suddenly it kicks in with directions only to go silent again a few minutes later
Anonymous
Level 2:
  • Expert 84 Answers
  • Posted on Aug 15, 2009
Anonymous
Expert
Level 2:
Answers
84
Questions
0
Helped
22938
Points
186
Try downloading the latest GPSfix updates using the tomtom home software
2helpful
2answers
My tomtom one gps can't get signal
When was the last time you updated the QuickFix of your TomTom? It helps your GPS to find the satellites.
Please, do the following:
1) Install "TomTom Home" software in your computer from www.tomtom.com
2) Start TomTom Home in your computer
3) Plug in the GPS dock to your computer's USB port and place the GPS on the dock. The green light on the bottom right of the GPS should turn ON to indicate that the GPS is getting power from the dock and charging
4) Start your GPS while being in the dock. If the GPS asks "do you want to connect to computer" answer "YES"
5) The TomTom Home software will detect the GPS and check if there are any updates for it. Then you'll be offered updates to install. Some are free, some are not. Be sure you choose to update "QuickFix".
Please, report back if you need further assistance
My ID: alexocuello_
1helpful
TomTom slow and sometimes won't configure to satellite
All gps units do not do well trying to find a satellite on the move. You should let your unit locate satellites before you start moving.
3helpful
2answers
My tom tom has lost gps help! all of a sudden half way through a journey my tom tom lost all GPS signal and wont pick up anything? is there anything i can do to get it back?
here are some tips on what to do ,To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays grey and one of the following messages is shown in the bottom right corner of the Driving View:
  • Waiting for a valid GPS signal
  • The GPS signal was lost sec ago
Note: In previous versions of the TomTom application the message may vary.
If you see any of these messages, try the following:
Finding a GPS signal
In the following cases it can take up to 5 minutes to find your current position:
  • You use your TomTom device for the first time.
  • You haven't used your TomTom device for a longer time.
  • Your TomTom device has been relocated without using it (e.g. after travelling by plane or train).
If it takes longer than 5 minutes, make sure that you are in an open place without tall buildings or trees around you.
Once your TomTom device has located your current position, the Driving View is shown in full colour and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster. Flight mode
On devices with built-in GPRS connectivity, flight mode also disables your device’s GPS reception.
To switch flight mode off, tap Flight mode in the preferences menu and then select Restore connections.
Clear View
Your TomTom device must be outdoors to locate your current position.
Try repositioning your device in your car; ideally, try to position it at the lowest possible point directly on the windscreen.
Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your device from locating your current position. If this is the case in your vehicle, use the TomTom External Antenna Kit (available as an accessory).
Tip: As a reference, place your device outside your parked car to see if it can find your current position.
Reset your device
Reset your TomTom device. Click here to learn how to reset your device.
Install the latest application
We recommend always having the latest version of our application installed on your device.
Does not acquire satellites. Tried waiting.
try updating with the latest GPSfix updates from the tomtom home software
5helpful
2answers
Tom Tom loses GPS reception as I am driving around
Have you hooked your GPS to an internet connected computer lately?
The TomTom home software that comes with the GPS will update so that it knows were the satalites are for the next week. It will also update the software to the latest verson.
You could also try inserting the end of a paperclip in the reset hole on the bottom of the GPS unit.
If all this fails contact TomTom. I have found them very helpfull.
3helpful
2answers
Waiting for valid gps signal
Try resetting your device. Depending on the model you have, this is done by either using the pin or holding down the power button for about 15 - 30 seconds. You'll know the reset has been successful when the legal agreement come up when it comes back on. Once this is done, go outside and on the device, go to the satellite detail screen and wait until several (about 4) of the bars are 75% or higher (they should change colors). You should go the the regular screen after that and you should be able to navigate again.
2helpful
Delete 1 or 2 journeys from my tomtom
If you are talking about recent destinations, you can only delete all or nothing...
BUT, if you use Poiedit, (www.poiedit.com)
you can open mapsettings.cfg on you unit and delete destinations, and resave file...
2answers
INVOLUNTARY CHANGES OF ROUTE/DESTINATION
You've done the hard (full) reset aswell?
Is it still under warranty? I've seen a few odd problems like these with tomtoms.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
