Question about Amphion Mediaworks M-270 Portable DVD Player
Video ribon cable
Does anyone know where to get a replacment lcd to main borad ribon cable?
Axon they carry this item!
Posted on Sep 17, 2008
SOURCE:
I have a minolta PagePro MF 1380 it notice on LCD SYSTEM HALT what must i do
you need to replace the main borad, this error means that is a problem to comminicate with video board, so you have to replace your board to get your printer working fine. thanks.
Dec 17, 2010 | Konica Minolta PagePro 1380 MF Laser...
Two vertical line in the screen???
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..if this fails then change the cable cord ....
Sep 23, 2008 | Memorex MLT3221 32 in. LCD TV
I have a Polaroid 40" TLX-04011C. The screen resolution is fine except for about a 4" area along the right side from top to bottom. This area is lighter than the rest of the screen. The picture is still...
I have not repaired this particular model. But I have repaired another polaroid flat screen TV. I can tell you for sure, the biggest problem here are bad capacitors in the signal board. You may find 15 or 20 bad caps. On the power supply there may be a two or three caps that need replaced as they will be weak but not real bad. Yes,the majority of the caps will be found in the signal board. You will need a good capacitor checker to locate these. It will require patience and skill to remove and replace these caps. I cannot say enough of bad capacitors in this TV. Find a TV tech to help you! Thanks for asking, show me a few hands of appreciation. This answer is your best effort for repair!
Sep 19, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Hi I have a new sanyo xacti vpc-ca9. It will not boot up - just a blinking red light on the top. The battery is charged and there is a 16GB SD card installed. Any ideas? Garth [email protected]
I have the sam camcorder. It has the same problem. When you press the on/off button, it does not do any thing just red light blinking on the top. After wandering with buttons without really knowing what I am doing, I took it to Sanyo service center. They found the ribon connecting the LCD to main body being damaged. They replaced it and charged me $75 for that. After that the camcorder works good. I saw the ribon is very vulnerable. If you twist the camcorder just a little hard, that ribon may get shocked.
Aug 04, 2010 | Sanyo Xacti VPC-CA 9 Flash Media Camcorder
My destak computer fujitusu with monitor compaq q2159 no possible for use in mointor going to sleep please help me
it means problem with Cpu.
first open cabinet.....Refix the ram...video Cable ok resolve the problem,
if without ram nobeep sound is coming it means foult with mother borad.replace it,
Mar 24, 2010 | HP Compaq Q2159 21.5-Inch Widescreen LCD...
I have the westinghouse monitor ( modeL # lvm-37w1) nad the picture keeps going nuts on the left side of the monitor only. anyone know what could be wrong?
Hello, this model has two ribon cables that run from the t_con board to the panel, it sounds like you might have to replace one of them if not the whole t_con board. You can find parts for this at www.shopjimmy.com, I would recommend you taking this unit to a certified repair center if you are not atleast a bit technical because you have to did a bit deep in to the set for this one.
Nov 21, 2009 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Dell Latitude D620 no display on main screen!!
If you have already replaced the LCD inverter cable and still the problem is there . You also told that the display is working fine when connected to the external monitor. This mean the Video controller on the motherboard is fine. This lead us to the conclusion that you would have replace the whole LCD assembly and not the inverter cable alone.
Thanks for using fixya
Proton
Aug 31, 2009 | Dell Latitude D620 Notebook
Rear NIC Light blinking
I found one of these printers in a parts bin and it looked like it was in great condition so I said what the heck, I'll try it out. Had the blinking light problem and figured it was a nic card because all functions via USB worked fine. If I plugged in a network cable, it froze up all functions except the LCD menu.
Took off the side panel and low and behold, it had taken a bad fall and the NIC card's connector to the main borad was busted. The main borad was fine though so it does everything fine via USB. Its a modulear NIC card so replacing it would probably work, but the chance of finding a replacement NIC card for the printer? Slim to none, it doesnt even have a model number. Only if I come across another one of these printers. Oh well, sweet printer for free, even if it only works via USB.
Apr 29, 2008 | Dell 1600n All-In-One Laser Printer
EM 500 RIBON CABLE TORE how to replace?? HELP!!
It might be possible to repair the tear. You'd need to bond a plastic backing to the back of the ribbon to support it. Clean off the front layer to expose the torn conductor ends then paint a thin strip of conductive epoxy or car heater matrix repair along each of the flat wires. Finish off by covering (when set) with scotch tape. Everything needs to be completely squeaky clean (use alcohol) before you start.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Amphion Mediaworks M-270 Portable DVD Player Logo
Top Amphion Mediaworks Televison & Video Experts
Ekse
Are you an Amphion Mediaworks Televison and Video Expert? Answer questions, earn points and help others
