Question about HP iPAQ hw6515 Pocket PC
PHONE WONT TURN ON, HELP!!!
Hi, where is the far left calendar or far right Itask or the battery lock switch as mentioned from the previous posts? I cant turn on my new hw6515 this morning. I was charging it from my pc last night for the first time. Then I disconnected it this morning and took it to work. Now, it will not turns on. I cant do soft nor hard reset, any suggestions? many thanks
  • 25 Answers
Hi, did you try taking out the battery and letting it discharge overnight then pop the battery back in, plug the pda into the power mains and try to turn it on again?
Posted on Dec 03, 2007
SOURCE:
On IPAQ hx2700, how do I do a hard reset? I want
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
Power on problems
  1. some times it may in loose contact or cool reboot problem, switch off, check and clean all contacts, refix it
  2. in my view after a long time its cooled that make this contact problem, when it warm up this effect is eleminated
  3. it may happened some old systems
Jan 20, 2008 | HP iPAQ HX4700 Pocket PC
Tip
HATD RESET HP iPAQ rx3115 / rx3715
While holding down on the far left (Mobile Media) and far right (iTask) press in on the reset button (reset hole) with your stylus for about 2-3 seconds.
on Mar 10, 2010 | Cell Phones
Tip
HARD RESET HP iPAQ h5000 Series 5450,5550 5555 HP h3800 Series 3830 3835 3850...
While holding down on the far left (calendar) and far right (iTask or Today) press in on the reset button (reset hole) with your stylus for about 2-3 seconds. After you see the screen fade, you can verify the hard reset by pressing the power button. If the device does not power on, then you have successfully reset you unit. To reactivate the battery you must either connect the iPAQ back to AC power or press the reset button again with your stylus
My ipaq hx 2415 will not go past the ipaq screen reset screen
Have you tried a hard reset (deletes everything)
2. While holding down these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
Mar 18, 2009 | HP iPAQ HX2415 Pocket PC
Power-on delay
some software program is causeing it to slow down.
try uninstalling some of your programs, or preform a hard reset witch returns the pda into the original state.
How Do I Perform a Hard Reset?
Perform a soft reset when:
  1. Press and hold the Calendar and iTask buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
    CAUTION: If you push and hold the Reset button for more than two seconds, the battery disconnects. To restart the unit, either plug the unit into the AC Adapter or press the Reset button again.
Mar 23, 2008 | HP iPAQ HX2400 Pocket PC
Tip
HARD RESET HP iPAQ h2000 Series (2210 / 2215
While holding down on the far left (calendar) and far right (iTask), press in on the reset button on the back of the unit for about 5 seconds. After you see the screen fade, release all buttons. You can verify the hard reset by pressing the power button. If the device does not power on, then you have successfully reset you unit. To reactivate the battery you must either connect the iPAQ back to AC power or press the reset button again with your stylus
6515 wont turn on "help"
you should try to do a hard reset. While holding down on the far left (calendar) and far right (iTask) press in on the reset button (reset hole) with your stylus for about 2-3 seconds. The Pocket PC should reset and power back on. If the device does not power back on, make sure that the battery lock switch is to the left (locked).
Oct 09, 2007 | HP iPAQ hw6515 Pocket PC
How do I do a hard reset
Hold down the calendar and iTask buttons, and then press the reset button for about 6 seconds. The Pocket PC should reset and power back on. If the device does not power back on, make sure that the battery lock switch is set to the left.
Sep 26, 2007 | HP iPAQ hx2410 Pocket PC
Can somebody help me please??
Sep 23, 2007 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
105 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
