Question about EliteGroup PM800M2 Motherboard
Problem When the pc tra?­a buy Linux installed, preo try to install windowsxp and all installation discs that attempt to use the machine does not recognize when this reading files gives a erreor blocking the machine.
    Problem Solver:
  • 17 Answers
The WindowsXP setup program will hang when it tries check hardware at the beginning of setup. It won't recognize the linux file system as a legitimate drive and freeze. You'll need to either format the drive and lose all the linux data, or buy a second drive to install Windows on and make the windows drive the primary drive, and temporarily disconnect the linux drive. After you install Windows you can reconnect the linux drive as secondary. You can check the forums for your version of linux and find help on setting up a dual boot system so you can boot from Windows and linux. You'll just have to make adjustment to the linux bootloader config file.
Linux is a great operating system, but is not for the faint of heart.
Good Luck
Fnshman
Posted on Nov 29, 2007
SOURCE:
My e-machines had windows 7 and became unusable. I had to use my pc and resorted to installing linux on it. I got the recovery discs from e-machines and after I put in the 1st recovery disc, it said...
You are getting this error because linux is installed on it.
Windows doesn't go well with linux.
Format your harddrive using any 3rd party formatter tool.
I mean, it should be like a blank hardrive without any files in it.
Then try to use the recovery disc.
Oct 02, 2011 | E-Machines eMachines Desktop PC
How can i install windows xp on the acer power 6800?
Hi ,
You can't download the O.S but you can buy the install disc here : http://pcsupport.about.com/od/windowsxp/f/download-windows-xp.htm
Don't forget to back up the drivers before launching the XP install disc .
Best regards .
Jan 25, 2011 | Acer Veriton 6800 PC Desktop
Boot loader for fedora8 & windowsxp
Boot a Linux Rescue Disk and Re-Install Grub with the command. "grub-install"
mount /dev/your_boot_partiton /boot
grub-install --root-directory /boot /dev/hda
The Boot Sector is Stored on the first 512 Bytes of the physical Disk.
Sep 23, 2009 | fedora Linux Operating System
I HAD WINDOWS ON MY ASUS EEE900. I HAVE RE-INSTALLED THE LINUX FROM THE BOOT DISC SUPPLIED WITH THE MACHINE IT LOADS OK AND THE MACHINE WORKS BUT IT WONT SHOW THE SECOND 16 GIG DRIVE. WHEN I GO INTO...
You should first (with or from a Windows CD) delete all partitions on all drives .... NON-DOS Partitions etc before you do the LINUX installation. The drives must be like when they were without any format or partition from the factory. Then only will the drive (all drives) be visible for linux to format with it's own information..
Jul 07, 2009 | ASUS Eee PC 900 Notebook
Can't install WINDOWS.
Install the XP Pro first, install the necessary drivers etc. Then after that load the other disk for windows XP Home install it choose the drive to install the OS, install the necessary drivers etc. you will see two operating system while going to boot section of the computer.
Mar 11, 2009 | Dell Dimension 8400 PC Desktop
How to install linux on compaq presario cq40-144tu
hrm... i'll just assume that this is the first time you've attempted anything with linux? There are vairous Linux distributions, with the Ubuntu flavour seeming to be the best one for the windows to linux switcher (IMO). I would try a live Ubuntu disc first to make sure it's what you're after, which can be downloaded here
http://releases.ubuntu.com/intrepid/ubuntu-8.10-desktop-i386.iso
or if you're ready to dive straight in, here is the full version that you burn to a cd and then install
http://www.ubuntu.com/getubuntu/download
Nov 29, 2008 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Compaq coa presario v2000 lost driver
if u want drivers for Presario v2000 series please use below link ....
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=432984&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
on the link please select correct model witch u have ..
then select OS witch is win-xp,& download what drivers u want..
there is all dirvers & softwares for v2000
if this information is useful for u please Rate me..........
Jun 21, 2008 | HP Compaq Presario V2000 Notebook
Pm800m2
Hi you will need to contact the manufacturer of the computer,
Dell, Acer, HP etc [ not the motherboard manufacturer] and select their support option. Some manufacturers have a lock code on the hard drive and if you can get the unlock key then you will be ok. The only other option is to replace the hard drive.
Regards mistyman
Nov 28, 2007 | EliteGroup PM800M2 Motherboard
Problema
i have a problem with placing my power and reset and hdd speakers ledds can u help me plz wit sending me a pic
EliteGroup PM800M2 Motherboard Logo
106 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
